I happened to take digital images of the piece I posted earlier. Hot spots on the painted surfaces posed a potential problem. So I shot the piece about an hour after sunrise. Sky was still overcast so the light was very diffused, producing no glare - and almost no shadows. Could have put the camera on a tripod and used the time delay to get a better quality image - but the hand held shots are pretty decent.
Might be a way to get around nasty hot spots that go with light buld illumination.
It depends on the shape of the piece, how glossy it is and what color it is. A light box is not always the answer and on reallyglossy dark pieces can be worse than on camera flash. What you have to do is figure out is how to change that reflection.
On really glossy pieces it's going to be there. Change it so it's less objectionalble. I do this in the studio by making the light smaller. Glossy relfections help you see how glossy the piece is so if you do away with all of them you have a flat photo.
Outside on a hazy day works for alot of work but a dark really glossy piece will simply reflect the sky and look terrible.
I put together a tutorial on shooting really glossy work. It takes you through the different procedures for trying to solve the reflection problems. I try several different approaches and show what the benefits and downsides are of each one. If anyone is interested send me an e-mail and I'll send the PDF
I also have on on controlling reflections on the top of the piece. I deal with this almost daily since I shoot a lot of glass and shiny ceramics. I have many more tricks that I can use with all the lighting equipment I have available but I've tried to show some techniques that can be rigged up in the home shop with quartz work lights.
My dad did a lot of BW portrait photography with his SpeedGraflex. And even with a battery of photoflood lights, with diffusers and bounce light umbrellas and halo lights, he'd still get hot spots that weren't apparent looking at the image on the ground glass back plate, seeing almost exactly what the negative would see.
I think I just happened to shoot this piece in a rare set of conditions - early morning sun low in the sky, coming through distant rain clouds, with an overcast sky over the piece - Mother Nature providing a Neutral Gray ambient light. A half an hour earlier the distant rain cloud had not come between the sun and the piece and even with the same overcast sky above the piece, I got hot spots. The left image is the Lucky Shot, the right taken 30 minutes earlier.
It's hard enough to turn a nice piece -and put a nice finish on it. These days you also have to be a pretty good, or perhaps lucky, photographer and even now videography is becoming important. So many learning curves to climb . . .
Charlie This is typical of some of the problems I have. This table is about 3 feet across. She likes lots of light underneath. I use a small softbox on the left because it produces a smaller highlight. We tried small hard lights but she doesn't like the shadows produced. We tried very large panels but they reflect in the surface and look terrible.
On the right is another slightly larger softbox. I need that to fill in the shadows. Again a large reflector just showed up in the piece. I use a polarizer which removes much of the reflection from the light on the right. This only works because the light is to the rear. A polarizer doesn't usually work with a softbox unless the light comes an from an angle greater than 90 degrees.
Depth of field is always a problem when shooting something this large and flat so I let keep the front and middle in focus and let if fade out toward the back. I'd like to use one of the DOF procedures in photoshop but it takes time and costs money and the customer is happy with this so I let it go.
She does wonderful candlesticks, mirrors, and clothes hangers and small tables all with a style similar to this. They sell really well. She's also really good looking and married to one of my best friends who is also an world class furniture maker.
