Well, it took me two days, but I made a first attempt at a natural edged vase of silver maple. This piece is 6" x 4"d and I had some trouble with interior gouge cuts near the rim on the inside. The round-nosed scraper did a good job in the lower half, but I was a little afraid to draw it up onto the rim. It is about 3/8" thick, and hollowed to 5-3/4" depth. Took a lot of resharpening all the way along. I'm hoping my next one will be better. Any and all suggestions are most welcome.
Hi Try sharpening the scraper as a negative rake scraper this means sharpen like you would a skew but in a radius .This should allow you to come right up the inside
If you drop me your contact details I can send you a picture if you like
Thanks John. Argh, more tools to buy. I have a Sorby multi-tip scraper tool, but am having a bit of trouble learning to use it. I ordered a 3/4" square scraper to cut down the insides with. Evidently I still need more practice sharpening, as evidenced by the tear out. Or, actually, I think I'm sharpening okay, but not often enough. I get to concentrating so hard, I forget to. I'll keep at it and try, try again. And consider buying another tool! I think I need Ruth's shirt: "We're all only one new tool away from greatness." ;-)
