Ive been across to Brisbane demonstrating at the Working with wood show for three days and came back a bit turned out. So didn�t get back on my horse for a couple of evenings
Back into the swing again so decided to do a bit more work on the Spirals piece
The three days away I thought quite a lot about were Id take this work
The frame you see is made from Rosewood and has been tenoned which I enjoyed doing as it�s a long time since I did any joinery
Great to shake the dust off the router again
I went to an engineering shop and brought some high quality bearings, so there is a bit of turning in the ends to house the bearings and some more to make small axels
The work know spins freely
Attached are what I think are some novel ways I turned the components
One being the legs that had 5 overlapping bowls turned up the middle
Two being the 24 small over lapping bowls on each end cap
You might say why I didn�t just use the router to cut flutes < I didn�t want flutes I wanted and arc
Alby see I can turn round on a round that is round
I havnt seen this type of use of the chuck before but I do use them like a tool to do what I want
Even turning the jaws inside out or using 3 or 2 jaws only in the chuck on odd bits of timber
Using 4 different sizes of jaws means all sorts of odd shapes can be held
Or placing the jaws in out of order makes some interesting turning
Using the slides only is common as they make great pin jaws
So What�s it going to end up being ? (Sorry you will have to wait for the next progress report
Comments always welcomed ( Oh to those of you that still think I am Crazy remember those that never venture out side the square never venture anywhere L.O.l )
Sorry just a bit of a grump why is Wc only 100 kb for posting pictures it would be far easier if irt was in line with all the other threads having to make up special sized photos for this site for someone like me who doesnt understand computers is a pain in the ......
I'm thinking I'll adapt some of the things you're showing and make them a little unique to me - not the spiral yet, can't quite figure where that would fit into my thought process, but it is certainly COOL!
Most color within the lines. Some ingore the lines completely and even go right off the page. And a few work outside, or way outside The Box. Then there's Terry - who - finding even this planet a bit constraining - heads out and finds new DIMENSIONS.
To think up Off The Wall, WAY WAY Out There ideas for a piece takes imagination most of us don't have (or haven't used). To make just one of these ideas takes considerable skill - and what seems like a total lack of a self preservation instinct ; ). To actually end up with a really nice and very interesting piece - just once - would qualify you for Sainthood (it's a MIRACLE!). But then to be so prolific?
What really astounds me is The LIttle Woman - who puts up with all this - and probably is very supportive of her husband's passion/borderline insanity . . .
He was the first one that I saw who was doing work mounted off center. It's wonderful work and often doesn't look turned at all. Terry's work reminds me of this with the exception that his usually does look like it came off the lathe. Both are very exciting.
When Jimmy Clewes turns the RPMs up, the crowd usually parts like the Red Sea. Escoulen also had a clear path in front of the lathe when I saw him. When I demo, if the lathe is running fast, only the new guys stand real close because they don't know any better :-)
Only once had something come out of the chuck at a demo in front of a crowd... of non turners! I told them "That means it's done" :-)
I first met Stoney at an AAW meet in Colorado Springs about 15 years ago. His work is wonderful. Every time we head down to Asheville, I stop in at the local gallery to see if they have any new pieces. His brother, Bartee, is a supporting member of WoodCentral.
Stoney was turning footballs for us at one of our old American Woodworker shows, and I was mortified by visions of what could happen if one of those puppies ever took off, which it actually did at one point. That's why they have cages over demo lathes. At least the careful promoters do.
