Need WC Help - Stop Collars
bowlman
I need your help, please. Does anyone know where I can get some stop collars with a 1" inside diameter? None of the box stores around here carry them.
Thanks in advance!
bowlman
Thanks in advance!
Re: Need WC Help - Stop Collars *LINK*
Dave Peebles Lyons, Ohio
Hi Dick,
Will these work for you?
Dave
Stop Collars
Bill Turpin in WNC mountains
Try this: also MSC, Grainger, Enco
collars
Mike Mills
You didn't say what the use was for.
If only to hold the tool rest a certain height while you swivel it to a new position (and then lock it down again) I use hose clamps from Autozone. They have some with a large thumb screw which makes it easy to adjust. No fiddling around with an allen wrench. They are about $3 for a package of two.
Mike
robo hippy
In the "I am too cheap to buy one" category, turn an end grain cylinder 1 1/2 inch or more in diameter, bore it out with a 1 inch forstner bit, then ream it a bit with your favorite hollowing tool, and cut to length. If you want to get fancy, you can make about a 1/16 recess along most of the length, and wrap it with colored nylon string construction string. Stronger than the plastics, and it won't shatter.
robo hippy
Rob Wallace
I buy mine from our local Farm Supply store (Theisen's), but any store which caters to agricultural implements and supplies (e.g. Tractor Supply Co., AgriSupply, Agway, Farm & Fleet, etc.) should have 1" ID stop collars with set screws. I have several, and use them on my tool rest shafts to set the height for one-hand rest re-positioning.... I also use them on my MacNaughton coring tool rest to re-set the tool to center-line each time. Very useful accessories at less than $ 1.50 each.
Should not be too hard locally to find before you have to move to Enco, MSC, Grainger, etc, via catalogs or on-line.
Rob Wallace
bowlman
Thanks everbody! WC is such a great resource!
Dick Hines
I made a collar for my coreing rig. I just cut a piece of gray electrical conduit to the right height and set the tool rest in and it is always on spot.
or...
GaryG in MD
If I don't need high accuracy, I just cut an old wine cork to length and drill through the middle of it. With the cork on the drill bit, go to work. ...Gary
Re: or...
Rob Wallace
Gary:
I think bowlman was looking for a 1" inside diameter stop collar (actually, a shaft collar) for use on a tool rest post. I don't think he would be using this for drilling, but this is a good tip. Not sure a cork would fit the bill for a 1" tool rest positioner.... unless is was a cork from a Grande Reserve Super Magnum Bottle! That would be one whopper cork!
Also - bowlman - I forgot to mention..... When I use a shaft collar on the tool rests that need to be adjustable, I replace the set screw with a thumb screw and can easily make fine adjustments as necessary.
Rob Wallace
Re: or...
GaryG in MD
You're right, Rob. I allowed too much time between reading the post and replying to it with generic "stops" in my head. Corks do work well for little stuff. ...Gary
