ADVERTISE HERE - FREE TRIAL
Some pieces completed........
Andrew Bourke
Hi, I have not posted anything for a while so here goes!
This is the last of the Indian Mahogany that I had. It's about 10" diameter, carved with reciprocating carver and Dremel. Insipration is definately John Jordan pieces.
Comments and criticisms welcome.
Re: Some pieces completed........
Andrew Bourke
Here's another completed piece. This is from White Stinkwood (Celtis Afrikaner) an indigineous South African tree. It's about 4 1/2" diameter but has warped in the direction of the pith as planned. To accenttuate this I carved the pith a level down to seem as if there is a vessel within a vessel. The upper layer was pyrographed in the Molly Winton style and the lower layer was textured with a blunt point in a engraving machine. Tell me what you think.
charlie belden
Very interesting idea, especially since you planned the piece to exploit this wood's characteristic deformation as it dries. The pyro work accentuates the "vessel in vessel" idea and the carving brought it out more. The use of two colors and textures to get the effect you were after might have accomplished the vessel in vessel goal. Going the additional step of carving emphasizes the two vessels in one idea even more.
Lots of thought - and work went into this piece. The results is well done and the idea is something I've not seen before - so the creativity points get added as a bonus.
Interesting - and quite nice.
Russ Fairfield
I am sorry, but my attention is taken by the quality of your photo editing and enhancement on the Stinkwood piece; and not the turning itself. I think you got carried away with your photo editing and have given this piece an appearance of being unreal.
As it is I have no idea what I am looking at. The cropped bottom, the little shadow, and the yellow around it all give it the appearance of being unreal. The little "flyer" up from the bottom right curve makes me think that this piece was turned with the photo editor and not the lathe.
I am left with wanting to see what this piece really looks like. I think it would look quite good by itself.
fgvanatta
The first one is exceptional . . . the second not so much IMO - there just seems to be something "off" about it.
Frank
Steven Antonucci
I think it looks like what he shows?
steven antonucci
I think it was turned with the pith in, and it has elongated the center of the vessel into that football shape. I think the black section was burned, and the surrounding white section was carved in relief to give the illusion on being bound by the black section. I doubt that there is a lot of manipulation other than to cut the image out from its background?
That's what I am seeing...
Steve
Betty Scarpino
Re: Elongated vessel
Betty Scarpino
Andrew,
I like this idea and am wondering if you are going to make others like it, using green wood elongated? It would be interesting to see what would happen if you were to make ten of them. How would the concept evolve? I'd especially like to see what you would do with the center section, perhaps change it slightly with more of a curve outward or inward?
Nice idea!
Your other piece is lovely, but yes, certainly influenced by John Jordan. Why not try the other concept and explore something new?
Steven Antonucci
Because teh he'd be infuenced by Ellsworth :-)
steven antonucci
I seem to recall seeing some of David's work using this to elongate through different axis, including diagonally...
need a log with 11 piths in it to be new and unique...
Did DE Carve AND Vaporize?
charlie belden
Betty Scarpino
Re: Because teh he'd be infuenced by Ellsworth :-)
Betty Scarpino
Sure, influenced by David. And Helga Winter (who influenced John Jordan oh so many years ago). And Christian Burchard -- they all use elongated warping in their work, but adding the carving, which emphasizes the elongation and serves as a contrast to the smooth surface of the wood is something that could be worth exploring and might actually result in creations that are his. But it may take five or ten or maybe twenty vessels before he frees himself up from whatever direct influence helped create the first attempt. I'm sure we could also link his center, textured area to a number of woodturners, too. I'd like to see him take the textured area and create a long looping swirl to encompass one of the elongated areas. The textured area is somewhat formal, architectural, and rigid compared to the graceful elongation of the vessel itself. Thinking of a swirled, relaxed textured areas, wrapping around the vessel gives me goosebumps to think how cool that might be! (Suppose I could steal his idea?!)
We're all influenced by others and by things outside the field of woodturning. It's exciting for me to see someone be influenced, then move beyond that influence.
Steven Antonucci
I was being facetious :-)
steven antonucci
The minute that someone lays a carving tool to a vessel, it is automatically accredited to John Jordan's work. If you don't carve them, then you get accredited to David's work :-)
I think that there are very few pieces that are truly original, because the internet and various publications put so much information and technique at our finger tips. I thought I was doing something original once, until I realized that it was highly influenced by Marc Ricourt's work. Most people wouldn't even know who he is...
It might be interesting to have someone with a very broad view of the history of woodturning write an article for AW on some of the BIG names in turning and who their influences were. Perhaps even a six degrees of seperation or geneology chart?
Know anyone with connections at AW? ;-)
S
Betty Scarpino
Re: I know you were being facetious :-)
Betty Scarpino
Steve,
I might know someone at AW who would be interested in an article on influence. She would welcome the type of article that would focus on the concept of influence and the role that influence plays in an artist's work. I think it's a tall order . . . are you up to the challenge?
I know you were being facetious, but the tone of my reply was in deference for Andrew and the images he posted for comment. I sincerely believe that the elliptical piece has incredible potential.
Andrew Bourke
Good day everybody. Thank you for all the comments and ideas in your replies.
I feel like I'm in the process of collecting ideas and techniques and somehow melding them into something unique. As a matter of interest here's a pic of a before and after without any photo editing other than to scale the image size to fit.
I'll try and take this idea further - thank you for the suggestion
Steven Antonucci
I would need some help
steven antonucci
but, yes, I am.
Let's talk in Hartford?
Steve
Ray Carson - Lawrenceville, NJ
I like the Mahogony piece Andrew. Looks like a flower bud. Very Nice.
Ray
