Veritas - Innovation in Tools
Polyfil update
Polyfil update
Polyfil update
I had time to do a few more tests. I poured it out so it was thin along with West System epoxy. At about 1/8" thickness both were flexible but the Polyfil is really flexible. Much more than the epoxy. It's quite rubbery feeling.
The batch I mixed in a cup was turned and sanded. It polishes well but shows the grit lines so you can't skip any grits and have to work a little harder with the finer grits. I haven't had the time to see if it really polishes to a gloss. It does polish up high enough for most work.
It has the same problem with bubbles as epoxy. I haven't had the time to see if you can use some of the same bubble removing techniques. Since it hardens so fast you would have to work very quickly.
So far it looks like good stuff with on e exception. It didn't bond well to the wood but I since I used plywood which is a worse case scenario that wasn't a real test.
