Home Made Spindle Steady/Rest
Hal Smith
I recently installed a bed extension on my mini lathe and find that when turning a spindle as short as 20" I get some to considerable chatter and vibration. The spindle rests on the market either won't fit between the ways on my lathe or are prohibitively expensive. Does anyone have plans, photos, etc. that I can use to make my own? Will much appreciate any help or guidance. TIA for any info. Hal
Re: Home Made Spindle Steady/Rest
Allen Neighbors
If you'll email me, I'll send you a short tutorial on how I made mine. It works.
DISREGARD! Didn't think of looking for your email... Doh!! I sent it to you...
Richard Allen
Richard Allen
A good bit of the chatter could be coming from to much tension being applied by the tailstock.
If you can mount the headstock end in a chuck then you don't need any compression from the tailstock to drive the spindle. Instead use the live center to "contain" that end. There will be a lot less flex introduced into the spindle while turning. Sharp sharp tools help because less force is used to cut away the wood. Light cuts instead of heavy cuts. Cuts made toward the headstock or tailstock. Cut instead of scrape. Cut the middle before the ends so that the greatest stiffness is available for the least supported portion of the spindle.
A spindle steady is nice but thoughtful turning can eliminate the need for a spindle steady in many cases.
Allen Neighbors
You're right, for sure... but... I don't recall anyone ever calling me thoughtful.... :D :b
Jim Canning
Allen I would love to get a copy as I am going to be making a steady rest in the next two weeks.
Thank you Jim
Hal Smith
Thanks Allen. Point well taken. I do have a 3/8" capacity chuck, so if I turn a 3/8 tenon on the end of my spindle blank, that would work.
Hal Smith
Oops! Thanks, Richard.
