Gesso question.
Scott Burr in Ben Lomond CA
I have never played with gesso. After seeing Carole's vase and finding it's unique magnetic qualities, I'd like to give it a shot.
Any tips on applying it and top coats (if needed)?
Thanks,
Scott
Gesso question.
Thanks,
Scott
Re: Gesso question.
Mike Foster
Take a look at the posts under Caroles pics again. Keith T. mentioned that he uses an airbrush to apply it. I haven't tried that, but it is on my short list of things to try. I recently completed a rather large piece that I used gesso on. It is mostly the inside of a tall hollow-form, so the final finish was not nearly as critical as with the outside of a hollow form like Caroles. I applied the gesso with just a brush, but very thin coats. It was not a perfect finish, but did not need to be. You can go back and sand the gesso with fine (800 or better) sandpaper to level it if needed.
I have been playing with little hollow forms and a variation on the Graeme Priddle wood vaporizer that I made. Decided to try little vessels ala Molly Winton, just because they are fast and fun. I did not try to control the burn, and just let it flame away (now that's fun) but it does leave a charred and not too pretty surface. Easiest way to hide it is make it all black. Now I have to admit that I really got lazy and decided that gesso was too much bother. I sprayed them with flat black paint for wood stoves. I think the result was just fine. Not quite as refined as with gesso, but quite fast and easy. I'll try to take some photo's tonight and post the result.
My topcoat solution
steven antonucci
I use a few thin coats of Gesso, leaving plenty of drying time. It needs to be finely sanded in between coats.
For a finish, I use wax, if anything. I found out (by accident) that it will take a shine if you rub it on an old pair of blue jeans. I was working on a carving, and I noticed that the front had been buffed while I worked on the back, and that I had a colored streak on my pants.
That's what I do.
Steve
Thanks Guys!
