Laser Pyroing - On Curves
charlie belden
Laser Session #3 played with working on a curved surface - two 2 intersecting arc pieces - one 3" acrossed and 2" "thick, one 3 1/2" acrossed and 2 1/2" "thick". The design on the first one is about 1 1/8" diam, the other about 1 1/2"
Also looked into varying laser power. Results indicate you can go from very subtle to quite prominent so there's a range of nuances that would be difficult to impossible to do with a pyro pen.
Getting the designed located where I wanted it is tricky because the 0,0 location is the upper left corner of the image being used. Almost got that centering where I want it worked out - sort of.
Comments, questions welcomed. These are test pieces just for playing with the laser on a curved surface so please don't worry about the shape or proportions or aesthetic value or point at that the design isn't centered or located at an aesthetically optimize spot on the piece. I'll get to the Artistic Use later - honest.
Re: Laser Pyroing - On Curves
Steven Antonucci
Does it burn the wood in the lattice?
steven antonucci
Just wondering about the effects of the "untouched wood" when you are burning that deeply? Does it burn the just the edge or is it deeper into the lattice?
I could see this being used to pierce a vessel too.
s
fgvanatta
Interesting. Looks like there is some "unintended damage" on the periphery of the pattern.
Frank
Re: Does it burn the wood in the lattice?
charlie belden
Steve:
Yes it does burn the wood - and the higher the laser power setting and/or the slower the laser moves - the more the adjacent wood is affected. You can see this in the first picture. The sample on the left has crisp outlines of the high areas of the design and the area "burned" away is slightly discolored. The sample on the right, done at much higher laser power and the same speed shows loss of crispness in the high areas' outlines and much darker, and deeper affects in the low areas.
Now some of the deterioration of "crispness" may be due to the set up. The piece is held horizontally in a chuck which is held by a jig. The jig sits on the laser's vertically adjustable table. The table top is made of honeycombed metal, possibly titanium, supported underneath by a metal frame with a single center support. As a result, the "table top" can sag a little under weight - the piece, the chuck and the jig. When the laser head changes direction suddenly, the whole engraver unit moves a little and the piece/chuck/jig rocks - just a little bit. But that small movement may be the cause of some of the deterioration in crispness.
As to piercing - yes, the laser can pierce rather than just burn/char little dots - and has a "vector mode" for cutting. Rather than start at one end of the design and moving left/right, completing one line of dots then advancing foreward to begin another line of dots, it "traces" the vector outline you provide in the Corel DRAW file, following the vector line from its starting point to its end point. In "vector mode", the laser's power is automatically set to 100%. This results in the edges of the pierced wood being charred - black. And if the surfaces adjacent to the cut have not been given a finish - shellac, lacquer, poly - some of the "soot" from the burn will get on the adjacent surfaces and discolor them with soot.
Regarding charring of the burned surfaces (low areas) - I've read that doing a low laser power pass - a finishing cut equivalent - will reduce the blackening but won't completely eliminate the scortching effect.
When piercing/cutting, the "charring effect" appears to be a function of the wood being cut. Maple, and I'm told, cherry don't char much. Softer woods seem to char more, redwood and walnut for sure based on my limited experience.
There are things built into the laser engraver unit which can be used to reduce the "sooting effect" - compressed air being blown from in front of the laser beam, a dust collector exhaust which pulls air to the back of the unit - and the ability to have the laser burn Front To Back rather than the default Back To Front. By using the Front To Back option, soot created is pulled over the smoother, preferably coated with finish, wood rather than already burnt areas.
I've read that there's a waterless hand cleaner which will remove most of the soot - and some of the charring - without raising the grain as water would. This waterless hand cleaner has a mild abbrassive, possibly pumice, that might also abrade - similar to fine sand paper.
Lot's of variables with lasering wood. I know a guy who has a laser engraving service I'm going to tap for some experienced user's Tips & Tricks. I'll post what I find here as I find things useful.
Like any tool, this one's got a learning curve that's a bit steeper than I'd initially thought. But the capabilities to do things I couldn't do any other way seems very promising. What complicates things a bit is that there are multiple levels of things between my hands and eyes - and the piece (hardware, software and "peripherals" - one of which is MicroSoft. As a Mac user, dealing with MicroSoft may be the bigget hurdle to overcome.
Richard Allen
Re: Laser Pyroing - On Curves *LINK*
Richard Allen
There are laser engraver forums on the web. When you ask these questions on these forums what sort of feedback do you get?
Such as the forum on Sawmill Creek
Laser Engraving Forum On Sawmill Creek
Jim Rutten
Is it possible to do 2 burns at 20%?
charlie belden
Yes - you can make as many passes, at any power from 1% to 100%, that you care to do. And you can, in "combined mode" used for "low relief carving", as well as the other two modes (raster being burnig little dots, vector being burn lines at max power) - set the rate of travel - as well as the frequency (how often the laser fires per second). So there are plenty of parameters you can tweek to get different effects using the same design image.
The first step for me is getting a feel for what this laser engraver CAN do. The next step is putting CAUSE and EFFECT information together in a way I can use it later. That's going to require some methodical testing - and documenting - in a way I'll understand later. The intent is to learn some ways to use this tool, document what I've found so I can use it later - and maybe help someone else with an interest in using this tool get up the learning curve a bit quicker.
I have already found that very subtle, very delicate, nuanced effects can be incorporated into wood pieces - which can't be done, or at least I can think of another way they could be done, without using a laser engraver. Sandblasting and high pressure water cutters may also be able to do the job - but maybe not on wood.
charlie belden
Saw Mill Creek, suggested by Barbara Gill in an earlier thread, apparently is a Pay Site, albeit a very inexpensive pay site - $6 a year it seems. That's a bargain. Not quite the bargain WC is - but still requires sending a check - or paying On Line. I'm REAL hesitant to give credit card numbers, debit card numbers or bank account numbers to anyone via the internet. And since I don't use paper checks anymore, I'd have to get a bank check to send in - which is $15 for the service fee.
The Laser Engraver Forum on Saw Mill Creek is a recommended resource. Getting into it is the "challenge" at the moment. Unlike WC - there's no phone number or human you can give your card number to. But I'm working on getting in.
Peter Hyde
Charlie, CorelDraw 11 was released in a Mac version. Actually has Mickeysoft and Mac on the same CD.
Worth looking for. I've been using CorelDraw for about 12-14 years and the Mac version kept me sane. It doesn't like SnowLeopard but runs good on Leopard.
Doug Thompson near Cleveland
Charlie,
This is interesting, Sawmillcreek is a free site just like this one except if you type WC overthere the post would be edited... different rules. I'm waiting right now for a Epilog mini 24 to be delivered next week, it should be fun but not my thing.
fgvanatta
Hmmmm . . . I go on the Sawmill Creek forums every day, and I haven't paid a cent yet. The "Engraver's Forum" - which includes laser engraving - is located at the link below.
Frank
Sawmill Creek Engraver's Forum
re SMC
charlie belden
I've registered on SMC, got e-mail with the user name I provided and a password to long in with and the change my PW once in. Did that, got in, this time could view images attached to messages - BUT - could NOT reply to any messages and couldn't create a new thread. I've gone through the first 7 or 8 pages of the laser engraver forum but finding threads on topics I'm interested in will take some doing.
Like any forum, there's going to be a learning curve. Read the FAQ but will print it out and take some notes for questions not covered in the FAQ. There does seem to be two levels of access - one free and one that does cost money - but seems to be only $6/year. Seems promising.
