Oil bleed help.
Oil bleed help.
Steven Antonucci
Oil bleed help.
steven antonucci
I read where some folks are using oil to highlight the ambrosia pattern in maple. If you put oil on the non-stained (white part), it looks terrible. The contrast between light and dark is striking when done correctly...
I have a piece that I am trying this technique out on, and I have some bleeding at the intersections where the two sections meet. I'm going to try to sand them back carefully, but I would rather avoid the oil bleeding into the white sections.
anyone have any tricks to stop the bleeding?
Thanks
Steve
Re: Oil bleed help.
Re: Oil bleed help.
Russ Fairfield
In the old days we used shellac to stop the bleeding in the pine so the furniture could be finished.
You can also add color to the shellac.
