Non chainsaw turning
When I started turning I had a shopsmith. I cut up wood, glued it together and turned it. I did segmented turning, inside-out turning, platters, stools and table legs. I turned a lot of dry glued together wood back then.
When I moved to Cookeville and learned about green wood turning all I had was a bow saw and a hatchet. I drug wood out of the woods by cutting it to a length I could manage. Tied one end to a back pack frame and pulled it home. Most of it I cut up with a bow saw and ax for fire wood but I also got my turning blanks that way. I cut them to length, split them with the ax, and cut the corners off with a hatchet. I spent many hours at that bow saw and still have it.
I did buy a good timber saw from Lee Valley but shortly after that I was able to buy a chainsaw.
Re: Non chainsaw turning
Carole Valentine
That chainsaw made your life easier, didn't it? ;)
Doc Green
I think a person cannot properly appreciate a chainsaw without having put in a hundred hours or so pulling the end of a two-person crosscut saw, as was the standard where I grew up in (far) East Tennessee.
But, one of the crosscut saws, when properly sharpened and with the correct amount of set in the teeth, is/was a remarkable instrument for cutting wood. In capable hands, it will go through a log quite rapidly and without a lot of effort. But "effort" is a relative term, and the person on the other end of the saw makes a world of difference in the effort required.
I learned it working opposite my Dad when I was about 14 years old. He had a special knack for explaining that you should not "ride the saw."
Long time ago . . .
~Doc
Jeff Rich
Ah the old saws.....
I never really got the hang of them, seemed to be a mismatch in power....
My dad is 6'2 and about 250, I am about 5'8 and 140......
He could really pull that saw!
After using some old dull hatchets and trying to get wood cut up decent, I took the plunge and bought a refurb at a local hardware store.
I think a good running saw makes you appreciate having one as well.
I just purchased a couple of old classic chainsaws that supposedly ran well.
Neither would run even after tweaking, spark plug and new gas.
Turns out, one had a bad carb and wasnt getting fuel, the other was flooding and had no compression.
Good news is I combined all the good parts and have a decent chainsaw now.
This also makes you appreciate the knowledge of all the people on various forums.
Drugging Wood
That was uphill both ways, right John? :D :D
I took a shortcut to getting wood home. Had an arborist / come out to the house as we had an oak that had to be taken down due to danger to the house. Made friends. Got to talking wood and he asks if I need wood as his company is always looking to get rid of take-downs. I said "sure!" A week later a stakebed crane truck showed up my driveway and unloaded. :O Loads can have everything from oak to cherry, walnut, mulberry, maple or poplar.
As my wife had absolutely no interest in doing the Pushmepullyou routine, I simply had to buy a chainsaw. ;)
Each time they drop off wood, my friend gets a salad set out of whatever they dropped off.
Is That Legal? :-)
Barbara Gill
Steven Antonucci
Turning B.C. (Before chainsaw)
steven antonucci
Involved a Sears lathe and a lot of money spent on Ebay.
One day, the power company came through and cut a deadstanding maple in the woods by my house. I went up, and I saw the spalt lines running through it. I borrowed my FIL's saw, and took as much as I could carry 100 feet to my driveway. Soon after, I realized that the cost of a chainsaw could be offset by not spending $$$ on Ebay. Done deal.
I also suspect that I could get my next saw by simply selling blanks on Ebay to folks that don't have chainsaws and access to all of the wood that I have access to cut. A few $20 cherry blocks or $30 spalted maples add up to the big Stihl pretty quickly...
Steve
Dick Hines
Re: Turning B.C. (Before chainsaw)
Dick Hines
Now here is a man who really wanted to be a wood turner. If I had to go through all of the get wood I would spend more thime fishing.
And Lawful Too
bill crommett
Does anyone remember the old Craftsman chainsaw that had teeth on a chain that resembled the teeth on a handsaw? It must have weighed 60 + pounds, because It wore me out in about ten minutes of cutting pulpwood when I was a husky 23 years old. I soon decided that a bow saw was more productive, because I didn't need to rest after two or three cuts.
