Vote Taken - The Eye Has It
charlie belden
Well this is close to what I had in mind for the hidden "box" in the pedestal of the Wishes Bowl - with lid and finial - and marbles - I was having trouble turninig. What I wanted was a surprise if you found the hidden box and opened it.
The marble "iris" sits in a concave hemisphere, the pupil and eyeball around it. Couple of coats of sprayed lacquer to seal the wood and give a glossy look, then paint brushed on FastKolor pearescent white I'd used on magic wands earlier, three shades of blue and a red Prisma Color marker sealed with more clear lacquer and then three coats of GOLDEN thick clear medium to soften the look and provide a wet glistening look.
Not quite the effect I was hoping for - but close enough to produce a bit of confusion - followed by a smile maybe?
Comments, suggestions and questions welcomed
Re: Vote Taken - The Eye Has It
Norm Smith
Now Charlie, That looks spooky. Well done.
Norm
"Interesting" is the kindest word I can use.
Russ Fairfield
Steven Antonucci
The pedestals are "iffy"
steven antonucci
getting past the shock value of an eyeball in a box, I really struggled with the pedestal and the handle/finial thing. I would have preferred a very simple, perhaps spherical, box and much smaller proportions if you needed the pedestal.
The eye effect reminded me of Monsters, Inc "Mike Wascowski, have you done your paperwork?"...
Cool, but weird...
s
Context Might Help *LINK*
charlie belden
This is NOT a stand alone piece. It's the pedestal for a Wishes Box inspired by Jennifer's Wishes Bowls.
The whole piece is a Proof Of Concept - a Wishes Box - with grooves inside the "box" and grooves in the lid - for marbles to roll in. It was not intended to be High Art, nor a refined aesthetic piece of wood art. It's an experiment playing with what I thought might be a fun piece - to turn as well as play with. It was fun to turn, fun to play with ideas as it developed - and fun to play with
Here's the context of the pedestal.
This was a fun piece that evovled as elements were completed and not a well thought out "designed" piece/ For some of the details of its evolution - click the attached link - if you're interested
Wishes Box evolution
Guy Bratt
I like it. Is there a bit of a rattle in the pedestel to lure one to open it?
Looking forward to the secound evolution.
Re: Context Might Help....sort of
Ruth Niles
Charlie, this picture and the angle make this piece look fairly nice. If it were large enough, would make a good looking bird bath for the garden. The finial with the marble is neat.....I'd like to see it sitting down in the bowl, like without....is that a lid? or just part of the turning that's under it?
I think maybe you tried to combine way too much into one turning.
Wish bowl, boxe, pedestal, bowl, finial, marble, eyeball, bright colors, plain wood, spalted wood, beads, coves.......more than my eye can handle in one piece.
Perhaps they each would excel when done separately?
charlie belden
"Is there a bit of a rattle in the pedestel to lure one to open it?"
Alas - no - but not initially by intent.
If you've turned a few lidded boxes, you probably work on getting the lid to box fit right first, THEN do the hollowing of the inside of the lid and box. Being a bit impatient, I removed only enough wood at the joint to test the fit, which left the wood high around the inside of the joint on both halves. Once the fit was good I started hollowing out the "box" - starting from the center. When I saw the concave hemisphere I HAD to put the marble in it. And when I did I "saw" the Eyeball possibility - and went with the idea - in the box. Once I had the Eyeball close enough - and not wanting to fix any more spiral cuts I'd been having, I started on the inside of the lid. Only then did it occur to me to "trap" the marble so it wouldn't rattle around and give away its presence - and location.
The eyeball idea, like the rest of this piece, was a serendipitous thing - that seemed to go with the idea of making something that was fun to play with and interesting to look at - no aspirations to end up with an elegant piece of wood art.
After playing with an image of this piece with PhotoShop, with some changes in size and proporotions, this piece COULD be developed into a more elegant piece. Might try the idea sometime - just for fun.
charlie belden
Ruth:
You're absolutely right. The piece evolved from the initial idea of a Wishes Bowl with tracks inside for the marbles to "race" in, a lid, also with a "race" for marbles, the lid added to make it a box, then a handle for the lid that became a finial - and also to hold a marble on top. Had I started with the idea of a chalice with lid - and more dry wood I could use - the results would probably have been more coherent and the proportions more pleasing to the eye.(see PIC in my response to Guy's message below)
What I got was a piece that's fun to play with, has a surprise that's pretty weird but fun, lots of practice doing different types of turning, some familiar, some "challenging" - and ideas that may be used for a chalice - with lid - and handle. Hopefully, daughter-in-law will get a fun "box" - with a secret (she loves little boxes) - she and her kids can play with.
Is it ART?
Certainly not.
Was it fun to make?
Absolutely.
Is it fun to play with?
I've enjoyed playing with it.
I turn mainly because it's fun and interesting. And I like to do things that are different from most of the pieces I see here and elsewhere, though I'm not opposed to "borrowing" ideas and using them in stuff I do - or try to do. Since I;m not doing things I intend to sell, I have the luxury of pursuing Wild Hare Ideas. By sharing some of this stuff maybe someone else will "borrow" something they see in my stuff - and use them in their own Wild Hare Ideas.
Turning doesn't have to be "serious". I can be "serious" if necessary, but I prefer to have fun as much as possible. This one was definitely fun.
Re: "Interesting" is the kindest word I can use.
bill crommett
I only wish that I had Russ' diplomacy.
