Platter for parent's 50th
Craig Daymon
I borrowed time in a friend's shop to make this platter. It's 17.25" in diameter. I haven't done much turning in the past 2 years, being confined to a 1 bedroom apartment, so it was a bit of a challenge. I burned the dates into the front lip and the dedication into the back. Had some headaches with finishing it, but since my finishing room is the living room of the apartment, maybe it was just the fumes.
I like turning platters. I wasn't taking any big chances with this one, but I like their ability to show off good grain patterns and the potential for getting creative on the lips. If the figure was plainer, I would have considered carving or burning something more than the dates on the lip of this one.
I like putting a button in the middle of the back equal in height to the outer bead. My thinking is that it provides support in the middle if anything of weight is sat on it. (Possibly a non-bead base wouldn't require this.) I'd rather the button had more character than what I put on this one. The next one will be better. Does this button idea make sense or am I wasting effort on it.
In the one picture, you can see a bark inclusion. Most of that was filled with Gorilla epoxy mixed with Strait-line snap-line chalk, black/permanent. It worked pretty well and the chalk is cheap. Did have to hit it with a heat gun to get it setting though.
The folks will get the platter on Sunday. Don't tell them about it, it's a surprise.
Questions and comments welcome.
-Craig
Re: Platter for parent's 50th
Very nice!
David Walser
I'm sure your parents will love it. Hopefully, it'll be passed down within the family.
As to your button on the back idea, I don't think it's necessary for strength purposes. At least, I've never had a problem with any of the platters I've turned lacking support in the center -- and we all know personal anecdotes are the best evidence there is. My concern would be it would give the platter a better chance of rocking. If the wood moves such that the center becomes higher than the edge of the foot, the platter will rock. Other than that possibility, I don't see a downside to using the button. It looks really neat, so it clearly has some upside.
Re: Very nice!
Donna Banfield
Don't know anything about the strength of a button on the platter, but your woodburning (dates and tribute to your parents) is about the best I've seen. Is that by hand, or did you have access to a machine to do that lettering?
Nice figure and a nice platter to showcase it. You're a good son!
Barb Siddiqui
Very pretty!
Barb Siddiqui
Re: Very nice!
Craig Daymon
Thanks.
To do the burning, I used a relatively small writing nib. The text was printed out and then transfered to the platter using graphite paper. (Office Depot sells it as Carbon Paper, but it is NOT the blue ink stuff. This is dry, tracing paper think and doesn't transfer color just by brushing against it.) I just had to try not to color outside the lines. Truth is, there are some spots on the dates on the front that went deeper than they should have because I didn't keep the tip moving.
Believe me, my handwriting does NOT look that good.
I did a larger 20" platter about 2 years back. The wood was spalted and the tray was possibly just a hair thinner. Very similar design and I think that one benefited from the button. This one is stronger, solid wood and not as big, so the button is probably very optional. Great spot for a small carving though.
-Craig
Dale Jablonski
Dale Jablonski
Nicejob, they will be very pleased. What kind of wood did you turn it from?
Texian
Beautiful platter Craig. I like the button idea. And ditto what Donna said about the pyrography. Very nicely done!
Beautiful wood and turning! I like the raised detail on the inside of the rim.
Our 40th anniversary is in a few months - feel free to make one for us too! :)
Craig Daymon
Thanks for the good words.
The wood was an AAA figured maple blank I bought from someplace that advertises in the back of Fine Woodworking. Unfortunately, that was over 2 years ago, so I don't remember which one.
-Craig
charlie belden
A nice piece is a nice piece. But one that has a lot of love put into it as well as skill and ability - those are priceless.
Well done - especially doing all the lettering - by hand.
Jerry McCaffrey
Craig, you certainly do nice platters. You are always welcome to come to NJ and use the Powermatic 3520 that I have in the basement and enjoy turning on. ;)
Jerry
