1 3/8 expanding collet chuck
Gary land
I have a colllet chuck that I have used to make pocket watches in the past. I have needed to make another watch and when I had turned the watch it was off center. I have taken it apart to look for sawdust thinking that I had a build-up somewhere ,but did not have any. I made sure the the chuck was seated properly. After i had put the wood blank on the chuck I had noticed that the jaws were not centered to the main body of the chuck. Could it be that the O- ring is to stetched? Any help wold be appreciated
Re: 1 3/8 expanding collet chuck
I have one....somewhere...haven't used it in a long time. I thought on mine the body of the chuck was 1 3/8 and the grippers retracted inside it. Then when you twisted it into place they came out and grabbed the work, but the body kept everything centered. Either my memory is bad or yours is different. I would check the "jaws" to be sure they function as they should and that they have not rusted or gotten a burr or piece of debris to stop them from expanding equally. I know you have already done this, but its worth another look.
Re: 1 3/8 expanding collet chuck *LINK*
Russ Fairfield
There is no automatic center on those little chucks, and it is usually only by luck that somethin just happens to be centered. I hold the square blank in a 4-jaw chuck for drilling and turning the face and inside. The last thing I do is then turn a short round on the outside that is concentric.
You could also saw the wood round with a scroll or bandsaw, use coping saw to do it by hand, and make sure the drilled hole is in the center of the piece. This will give you a concentric reference.
When I go to the little Penn State chuck for turning I now have a reference and I can tap it into being concentric. A final twist gives it a good grip for turning.
Or, you can ignore all of the above and just use the drilled hole as a visual reference to tap it into concentric before tightening it. I work the outside as a concentric reference because it is harder to see the rim of the hole.
Sometimes it helps to have the little chuck spinning slowly while the wood is held against it. This will get it centered most of the time. Be careful if you do this with a square piece of wood.
There is a description of this on my website at the link
Turning  the pocket watch
