New? Hollow Form
Don Central Illinois
Spent about 4 hours this morning working on a new hollow form only to have ti turn into firewood!! Hate when that happens.
New? Hollow Form
Re: New? Hollow Form
Terry Scott
Never firewood just becomes a canvas for another work carve it texture it paint it
add parts of it to another turning
Never say die
Re: Yup, you have a "design opportunity"
Russ Fairfield
Don, never throw anything away. Just because it's broken doesn't mean you can't make something else out of it, or puit it back together.
First look at saving what you have. If you look around, you will find photos of many pieces that use leather lacing, butterfly shaped tabs, string, gold and silver wire, and other ways to hold them together. Others are glued back together with lines of turquoise filled glue. Don't believe anyone when they tell you all of that lacing and filled lines was intentional. Drill a line of holes along the edges and start lacing them together.
I saw a thin hollow form at the Provo Utah Symposium that had been shattered into many pieces, and the lady had knitted the pieces back together with thread. I mean "knitted" like with knitting needles. She had developed a technique for doing that, and it was a wonderful "save" that looked better than the original.
Don't forget jewelry. There is nothing that says all jewelry has to be made of gold or silver. You already have a curvature. Cut out the shapes with a coping saw, sand and finish the edges, and you have a piece of jewelry. Thin wood makes beautiful jewelry like ear rings and pendants. You can buy the metal findings in both silver and gold at JoAnnes Fabrics
Always an opportunity
Steve Kubien
Everyone knows that some failures are catastrophic in nature. The trick is to recognize the ones that are not and that can be reclaimed. This piece was meant to be a hollow form but now it is an end-grain bowl...just what it always wanted to be.
Re: Always an opportunity
fgvanatta
"Firewood" is a synonym for "design opportunity."
Frank
Well, I did take another look at it this evening and I think I may be able to make something out of it. Just not what I had envisioned. At least it grows on trees, now all I need is more time. I will post photos when I get it finished. Thanks for making me think design opportunity rather than firewood.
Terry Scott
And a nice bowl it turned out to
Happened to me too
I had just finished reverse chucking the bottom of a nice little walnut pot and as I was taking it off the lathe, the little spigot broke and the pot fell to the floor. I seem to have more breaks off the lathe than on it these days.
Thanks Terry.
Steve Kubien
