How do we get this on a lathe? *LINK*
Craig Daymon
I just read and watched this video about an Australian inventor creating an Infinitely Variable Transmission. They keep saying it is enormously complex, but it doesn't strike me that way. I think it could have some very positive applications to wood turning and could easily (my opinion) be adapted to a wood lathe. Check out the link below (and watch the video).
-Craig
Re: How do we get this on a lathe? *LINK*
George Balock
George Balock
Wow that is brilliant. I'm curious how his testing will go.
Wayne Kuhn
I am pretty good with mechanical concepts, but this made my head hurt.
How to get it on a lathe? Bolts would be a good start ;)
Bob Macgregor
Interesting concept, but I'll stick to variable speed electric motor. This device on a lathe would need to be really well-sealed to keep out dust. Also, it would need to be powered, so you'd probably have the electric motor anyway. It would be nice if my lathe could have a broader torque range or a simpler switch between its two speed ranges, but I don't see those complaints as serious enough to warrant introducing a lot more moving parts though.
Now, when they put that in a car, motorcycle or tractor I might be more interested.
BOB
I don't think so
That seems a clever concept but the engineering appears problematic on several levels to me. When discussing the need to rotate the controlling shaft independently, he glosses over the issue of the torque needed for THAT shaft which may be considerable for vehicle applications. Note that he has to provide an independent VARIABLE SPEED drive for the controlling shaft which he provides in the prototype with an electric motor with a variable speed controller. How will he do this in production, with another one of these mechanical contraptions downstream, that driven by another...? His mention of "hybrid vehicle" sounds like hype.
The complexity of the gear systems needed also throws up warning flags.
Check back this guy in about five years and see if he's sold any.
