Indexed Pattern "Jig" Idea (not mine)
charlie belden
A turning club member shared this idea at last night's club weekly Saw Dust Session. He saw it used by a potter. The potter uses it to do repeating patterns on plates and bowls. The idea is fairly simple to implement and apply for repeating, indexed pyrography on a turning.
Re: Indexed Pattern "Jig" Idea (not mine)
Works perfectly. I've been doing it for years. If you place the tool rest,or in my case a router, on the center line it cuts a line that goes from outside to center (DuH). But here's the fun. If you place the tool rest so the line is above or below center it makes the finished piece look as though the lines spiral. Below the tool rest makes them appear to spiral CCW. Above the tool rest CW. Do both, the same amount and you get a cross pattern kind of like Knurling on a metal lathe. I'm talking about faceplate platter turning such as platters here.
You can use different carving tools, pyrography tools, flex shafts with different grinders, etc. There are a lot of possibilities.
You can use this technique on spindles of course, which is where I learned it. This is done to make flutes and beads on spindles.
You can use it on vessels. If you remember my cupcake boxes that's a good example of using a router with a V cutter.
Thanks for posting the drawing. It helps people understand the process better.
Charlie It must be too early. I meant to add that you can make forms to go either on the tool rest or in the banjo to any shape you desire. I've made thick plexiglass forms and use the router with a bushing.
I usually use a scroll saw and some scrap wood to make forms that I can follow with the flex shaft.
I like the concept of using 2 posts and bent wire. In some cases that would be faster and give more control. A couple of nuts on a piece of All-thread with a bushing inbetween them to hold the wire would let you fine tune each side of the wire support. Plexiglass or thin plywood would be stiffer if you want to try carving rather than pyrography. That's a cool idea, thanks for posting.
Don in central washington
don in central washington
guess I'm really denese this morning. Working alone like i do have never seen this set up in real time.Would one of u post yours?
tks Don
Jeff Morneault in northern Maine
What a great idea, Thank You for posting Charlie!
charlie belden
As always, there seems to be nothing actually new under the sun. And, as noted, this is not one of my "brilliant ideas" - that everyone already knows.
John:
I like the idea of making plex or temper board patterns for the guide in a router to follow - attached to the tool rest banjo - and adjustable for At Center, Above Center or Below Center (along with the CW and CCW explanation. Are you amenable of my doing some illustrations with accompanying text to post here and on our turning club website? If so, I'd appreciate e-mailing you drafts of the stuff for review, comments, suggestions and maybe additions.
PS.  Wire Can Be Bent To Follow Contours of Piece
charlie belden
The advantage of using a heavy gauge copper wire as the guide - is that it can be bent to follow the outline of the piece so the depth of cut can be sort of consistent.
The guy who turned our club on to this idea mentioned something about heat treating the annealed (soft) copper wire to harden it. Don't remember the details. Anyone know how to harden annealed copper wire? Just bending and shaping it will "work harden" it some but there is another way.
Charlie Since I can't draw a straight line you are welcome to draw all you want. I'll be more than glad to try and add my 2 cents worth. I've had success and some failures so Maybe I can keep someone else from having the same problems.
Re: PS.  Wire Can Be Bent To Follow Contours of Pi
Charlie To harden copper wire just heat it red hot and let it cool naturally. This is the opposite of hardening steel. Brass works the same way. Just bending copper will work harden it but you some wire doesn't get very hard when bending. I use a ground wire as a jig to hold artwork, gobos, reflectors and such at work and bend it constantly. It eventually gets very hard to bend from work hardening. I heat it red hot and quench it in water. That makes it soft again.
