turning paint-seriously paint *LINK*
Re: turning paint-seriously paint *LINK*
#2also known as Fordite *LINK*
Dick Coers
Very popular with jewelry makers. If that guy has boxes full of it, he's got some real money there. The original Fordite was paint that had run through ovens for curing, so it's really tough.
Fordite
#3Health Concerns?
Barbara Gill
#4Probably no worse than cocobolo for some people
#5Probably?
Barbara Gill
Is that a guess or based on facts?
#6purely a guess.
Barbara I would take the same precautions turning something like that as I would anything unknown. More than likely it's no worse than turning plastic but I wouldn't take the chance. I turn brass and aluminum and it's probably at least as bad or worse to breath the sanding dust from that as it is the hardened paint. I wear a mask in those cases.
#7Re: purely a guess.
bill crommett
Interesting. I have had a big chunk of that paint concretion for twenty years and never thought to turn any of it. I just kept it because I thought it was pretty. What a time the widow will have at the terminal garage sale.
I have several boxes of stuff I kept just because I thought the stuff was either interesting or pretty.
Re: Probably?
Jesper, Denmark
barbara,
the health exposure would be similar to, but with much smaller volume, what auto re-finishers are exposed to. The paint with the stuff and then sand it a few times, maybe 8 hours per day.
The particle size coming into the air while turning is much larger - and therefore less hazardous - than sanding dust. Also easy to filter out with a dust mask. sanding and polishing these small bits with a vacuum hose in close proximity ought to take care of that dust.
Having said that, I have no real data, only a bit of common sense.
the color pigments may contain a multitude of minerals and metal oxides and for sure some TiO2. If you feed tons of it to rats, they probably would not like it. Making an occasional finial will not register on any statistical survival rate.
