hand chasing thread size
Those of you who do thread chasing what is your favorite Thread pitch? I'm currently playing with 20TPI because the tool moves slower so it's easier to get a short thread. However on my threading machine I like how the much faster the lid is to remove on 16TPI. It's also easier to cross thread a 20TPI lid than a 16. At least that's how it feels to me.
I don't have a 16TPI hand chaser but do have a 14 so I'm going to try that out this weekend. I'm concerned that you have to get the tool out of the cut much faster to keep from running into the shoulder. Either that or slow the lathe down well below 200 rpm.
Re: hand chasing thread size
Allen Neighbors
John, I have some 20 tpi and I got a 10 tpi from Australia. I like the 10 best.
I have turned threads on my Little Vic at it's slowest speed... 680 rpm... using the 20tpi. Never could get the lid threaded to fit the box at that speed.
I use the 10 tpi cutter on my Oneway, and slow the speed down to about 150rpm. It works well, but you do have to get out of the thread quickly, or you hit the shoulder, and you know what that does.
Oh yeah, boxes with the 10 threads are much quicker opening and closing.
I'm really good at making 10TPI beads
Fred Holder
Hello John,
I have chasers from 24 tpi to 3.5 tpi. My favorite is a 16 tpi set made by Ray Iles in England and imported by Tools for Working Wood in the United States. I like the shape of the chasers and the feel of the handles in my hand. I personally like 16 tpi threads for lidded boxes; however, all of the smaller threads require hard dense wood or a epoxy insert. I've been able to chase 16 tpi threads in cross grain boxes in some of the softer woods. Cross grain threads hold up better in softer woods, but the box is much more difficult to turn when the grain goes across the box.
Thanks Fred. My cup cakes are cross grain but at 2" in diameter I have slight wood movement problems with the seasons. Those are 16TPI. The lids have a tight spot every half revolution when the wood shrinks during the winter. It's not bad bit I know the difference. I may have to get a way to measure the moisture in my shop and make fine adjustments for the seasons so movement is at least predictable.
