Disk Sander
Larry
What is a good speed for a 12" Disk Sander?
Disk Sander
Larry
Re: Disk Sander
Dave Peebles Lyons, Ohio
Hi Larry,
I have a 12" factory built disc sander that runs at 1725 rpm. It seems about right to me.
Dave
Re: Disk Sander
The speed of mine is also 1725 but If I built one from scratch I would put a variable speed motor on it. When you sand woods like Cherry it is way to easy to burn it. I try to sand near the middle which has a much slower surface speed but you just can't always do that.
My first tool was a Shopsmith and it had variable speed. I really enjoyed using the sanding disc on this tool because you could really slow it down. 500 rpm if I remember correctly.
Re: Disk Sander
bill crommett
My disk sander is a dedicated Shopsmith and I have no idea of the present speed, but I have done lots of cherry and not burned any of it -- yet.
Re: Disk Sander
Texian
Definitely variable. I frequently run my 15-1/2" disc at 150 to 250 rpm for sanding the ends of segmented half rings.
