How do you clean rifflers and rasps?
Donna Banfield
If Andi Wolfe or anyone else who uses these tools knows the answer, I would really appreciate some tips. Acetone? Mineral spirits?
These aren't the terribly expensive ones, but I can't afford to replace them right now if I damage them while cleaning. Thanks.
Re: How do you clean rifflers and rasps?
file card
Donna I use what is called a file card. It is often sold with metal files. It looks like a very short wire brush. I use it to clean my files and to clean my sandpaper that has clogged with wet wood or with finish if I used lacquer or CA glue to stiffen punky wood.
I've had them so long I don't know where to recommend getting new ones. I know the metal supply houses like www.mscdirect.com and www.use-enco.com will have them. You might find them at lowes or the local hardware. I haven't looked lately.
If they aren't really clogged a brass brush will clean them out.
Carole Valentine
Donna, be careful with the file card. Even though you say they are not really expensive rasps, you don't need to dull them. Michel Auriou (who in my opinion makes some of the finest rasps and rifflers around) suggest the following:
When you are done with a rasp, use a brush to clean and unclog the teeth. Don't use a file card made of wire (steel or brass), that will dull the rasp in time. Michel Auriou strongly cautions against this and suggests a short (3/8" long) stiff natural bristle brush. He also suggests that after cleansing, a light coat of camellia oil should be applied to protect the rasp from rust.
Dave Belser
Use a torch, lightly. Turn the crud to char and it will fall off.
Re: file card
What they call a rasp brush is what I use.
Thanks Carole- I'm a new owner of auriou files
Dave I may be wrong but I would be afraid to use any heat on a file. You could overheat the thin tips very quickly and ruin an edge. I do use heat to clean my carbide burrs. It won't hurt them.
Re: Thanks Carole- I'm a new owner of auriou files
Carole Valentine
Hope you haven't used the file card too much. I think you will enjoy the Aurious, John. I have only been able to afford one so far. My others are Gramercy.
Steve Kubien
Go to your drugstore and...
Steve Kubien
...pick up a denture brush. They have stiffer bristles than a regular toothbrush but obviously nothing like a file card or brass brush.
Ken Vaughan
Ken Vaughan
An old machinist taught me to apply a hammer to a nail and an anvil until the steel in the nail was paper thin then to use the thin piece to scrap along the theeth and remove the clogged material from the gaps between the teeth. The thin metal forms to the teeth and slicks out the wood dust and swarf. Save the nail and use it over and over again -- have a few that have cleaned lots of files. Different tooth spacing - new nail.
He was insistant that files that were used on steel were marked as such as they did not perform as well on softer metals or wood after use on steel.
Donna Banfield
Thanks Carole. They're not Aurio, but these are on my someday wish list. I've used brass brushes to clean my Kutzal rotary burrs, and the manufacturer of the DuraGrit Carbide bits says to use acetone to clean those, but my instincts were telling me that I needed to be cautious with the rifflers and rasps.
Donna Banfield
John, that's exactly what I was thinking. These are thin and several are curved to a point. The heat from the torch would change the temper (?) or in one case with my fine riffler, melt the tiny teeth. This, by the way, is the one that needs the most cleaning, as the teeth are barely visible. It still cuts, but not as well as it should.
Re: Go to your drugstore and...
Donna Banfield
Thanks Steve. I may have to look into that method, might even work better than a brass brush for my rotary bits.
Re: clean rifflers and rasps?
Donna Banfield
Ken, that's a pretty good idea, too. Now I just need to find an anvil :^) I think there are a couple of blacksmith hobbyists in one of my clubs that could help me out.
Doug Wolf
I use an air hose to blow along the length of the file, rasp, etc. after each use and very seldom have to clean them out along each groove.
Light Torching and "Simple Green"
Jerry Hall
were recommended by Pat Kramer in Utah last week for carbide cutters. But he cautioned about not leaving the cutters in the Simple Green for too long.
Donna Woodcraft has a file cleaning brush that has a metal file card on one side and brush on the other side. I forget the price but I think it was around $15.
A Tip That Might Work
charlie belden
This one I learned back when I was making jewelry. Metal would get packed down tight in the bottom of the "teeth". An old jeweler friend told be to "chalk" my files after cleaning - with black board chalk. the chalk gets down in the tight areas, preventing filings for packing in there. Made cleaning files SO much easier. Might work for wood as well as silver or gold.
Re: A Tip That Might Work
Ditto what Charlie says. I haven't tried that with my wood rasps but use it anytime I use the metal files on metal.
One of my file cards has a sharpened copper wire with a loop on one end. The sharp tip is great for picking out those stubborn pieces that don't come out with the card. That would be very easy to make. Just sharpen a piece of copper wire, heat it red hot and let it cool.(that's the opposite of steel and works for copper and brass) This will harden it so it doesn't bend as easily but it's still way softer than the steel.
Ken Vaughan
Anvil
Ken Vaughan
Does not take much to flatten a nail-- I use the one on the back of the bench vise most of the time.
Just a few blows with most hammers does the job.
Re: A Tip That Does work for wood
Russ Fairfield
The chalk does work for wood, and it makes the cleaning a lot easier. I use the powdered chalk that is used for chalk-lines on the wood rasps.
Yes, it does get on the wood, but is easilly blows off with a air hose.
