How to remove the hand wheel on a Conover lathe?
wilbur
I have a Conover lathe and would like to get to the bearings to regrease/replace them. I'm stymied by one thing: I can't get the hand wheel off to remove the spindle. I'm talking about the wooden hand wheel to the left side of the headstock.
I think that it screws onto the spindle, and is just stuck, but I'd like to know for sure before I start breaking out the big can of whoop-butt.
Does anyone know for sure how this hand wheel goes on the lathe?
Thanks!
Re: How to remove the hand wheel on a Conover lathe?
Ken Oakley-Sunny St. Cloud, Fla
If it screws on it might be a reverse,(left hand), thread.
Jake
IT is left hand thread. A couple of years ago I replaced the bearing on a conover (when I still owned it.) I ended up unscrewing the wooden par of the handwheel and using a soft jaw pliers to bust the aluminum nut free. It had me in a pickle as well. Picked up the bearings at a local bearing supply house.
Good luck
Jake
wilbur
Thanks for the tips! As Jake said, the hand wheel is screwed on with a left hand (reverse) thread. I had been trying to get it off by turning the hand wheel clockwise, so I was on the right track. It seems that all I needed to do was to let the Liquid Wrench soak for a longer period of time, and it eventually came off.
Thanks!
