Blonded Manta
Blonded Manta
Blonded Manta
Terry Scott
Sorry about the picture of this one had to get finished and off to a customer in a hurry
200mm square Burmese Teak
I left the inside plan timber so it draws the eye
Liberon liming was and lacquer to seal
Re: Blonded Manta
Re: Blonded Manta
fgvanatta
Hadn't thought of liming Teak - that's a great look, Terry.
Frank
Re: Blonded Manta
Re: Blonded Manta
charlie belden
Lets see, 200 mm square - about 7 7/8" square means the corner to corner diagonal is about 282 mm - which is about 11 1/8". Working with the photo, the wings are - about 4.5 mm or a bit under 3/16" or a tad over 1/8" at their corners. THAT is pretty thin - anywhere. But out at the tips of the square - where you're turning a LOT of air and just a teeny tiny bit of wood - that's unsupported 5 1/2" from center . . .
Terry - you've not only got a great imagination - but very impressive fine motor skills.
Now you're going to tell us this was turned with a skew - right?
If you successfully turned just one of these it could be just very good luck. But you've posted a half dozen variations of this idea - so it clearly isn't that you got lucky and turned one.
You're pieces are pretty amazing - visually. Technically - even more amazing.
Re: Blonded Manta
Re: Blonded Manta
Keith T
Hi Terry...love it.
Re: Blonded Manta
Skew in Use
Terry Scott
Hi Charlie
Yes mate with a skew or the wings anyway
Plus forming the spigot and the detail around the rim Oh and if you call my scraper a skew because it is sharpened like a skew except oval for the finish cut of the interior
Or the shear cut around the bowl The Skew is my friend l.o.l
Because all these vessels are cross grain I havnt found another way to cut them as cleanly as rubbing the bevel on the skew
Yes Teak or some can be very open grained so takes the wax well
Here is how I d it
