Face shield
Face shield
Face shield
Jim Canning
I am looking to buy the trend airshield are there any pro's or cons for this and is there something that works better?
Jim
Re: Face shield
Re: Face shield
D. Hansen
There are two versions of the Trend. I have both. Make certain you get the Pro. The pro has the battery pack further back on the head making it better balanced. There is an alarm that beeps when the battery is running low. The battery can be charged while still in the shield. Finally the filtration is about 2x's that for the first version. I think that the noise of the fan is better muffled but that might be my imagination. It is a bit heavier but because of the better balance it is easier to wear, at least for me. The down side. The brace that goes over the head tends to break at the pivot points. Trend USA has replace it both time when I called. I think I fixed it this time. I took a piece of aluminum cut it to fit the overhead brace and hot melted it in place. Now the weight should not cause the band to break. Try all pro tools they sometimes have the Pro version on sale and almost always now have the older version at good prices. As far as cost the replacement visor shield run about $26 for 10 and the filters $56 which is very high for consumables. All in all though it is an excellent item to have in your shop.
Re: Face shield
Re: Face shield
ted evans
I use the Trend Pro and have been very satisfied with it, have no knowledge of the others.
Re: Face shield
Re: Face shield
Chuck Johnson
I just purchased Trend Pro from www.packardwoodworks.com. They have them on sale. I saw somewhere that Triton will not be available until later this year.
The Pro works well and I love it. Don't have to worry with fogged glasses.
Chuck
Re: Face shield
Re: Face shield
David Walser
Jim,
The Trend Pro is a good product and several turners are happy with it. In the same price/quality range is the Triton Powered Respirator. I personally prefer the Triton and own one. The reason I prefer the Triton is because it felt better balanced and I thought it would be more comfortable for long periods leaning over the lathe. (The Triton's motor/battery/filter pack is worn on a belt around your waist, so that weight is NOT carried by your neck. In contrast, the Trend Pro is a more compact unit with the motor, battery, and filter part of the helmet.) The Triton's filters are NIOSH rated for dust and particulates, but not the fumes from paint and other chemicals. I like the fact the Triton provides more protection than does the Triton from impact (it has a "real" hard hat) and provides hearing protection. In addition, while I consider the Trend and Triton to be in the same general price and quality range, the Triton is more than $100 less expensive.
A significant step up in quality are the powered respirators from 3M. A number of professional woodturners use the 3M Airstream. It has a battery that will provide you airflow for a full day's turning and the filter will keep the dust out of your lungs. Like the Triton, the Airstream has a real hardhat and safety visor. However, if I were to step to 3M, I think I'd go with the BreatheEasy, which allows you to combine the Airstream's helmet and visor with a belt worn power/filter pack. The advantage of the BreatheEasy over the Airstream is the Airstream's filters are only good for dust and particulates. With the BreatheEasy, you can get filters for paint and other chemicals, in addition to dust and particulates. It does cost a bit more money, but I think the additional flexibility would be worth it.
Here's a link to Airware America, which sells all the systems discussed above. Note: I've purchased from Airware America and had a good experience. However, the products might be available for less money at other retailers.
http://www.airwareamerica.com/tritonworkshopsystemsrespirator.aspx
Hope this helps!
Re: Face shield
Re: Face shield
Bernie Weishapl
I don't know about the Trend Pro but I do know the regular Trend does not filter like it should IMHO. I even ordered new filters and it still didn't filter like I thought it should. I got a bronchial infection from wood dust according to my Doctor. So I purchased and now use a Airstream AS400. A friend of mine recommended it that works at the grain elevator. With the Trend I could smell the wood but with the AS 400 I cannot smell the wood anymore.
Re: Face shield
Trend Airshield Pro Filters
E Tabachek
How easy are the 2 main filters (that look like little padded envelopes) to clean? Are they easy to remove without getting the dust that is stuck to their surface all over the helmet innerds? How often will they have to be replaced?
ET
Re: Face shield
Re: Trend Airshield Pro Filters
D. Hansen
I don't think the filters are supposed to be cleaned but I do. they come off their fitting with ease. I just blow them out with low pressure air. Another thing I do that is probably not supposed to be done is to fit the filter material that is used for A/C floor vents between the fine regular filter and the top holes. they trap the big stuff very well.
Re: Face shield
D. Hansen
I did not answer your other questions. The frequency of change depends on how much wood you turn and if it is spalted, fine, or wet. I clean mine about every third battery charge or so. It is not difficult to keep the inside of the helmet clean. the filters do not seem to drop what they have collected.
