I bought a couple of the HSS tool tips to make an Ellsworth type tool. The tips are about 2" in length and I want to cut them in half. I have some cut off wheels for my Dremel and wonder if I could, if not cut them in two, at least score them enough to break them in two. Any and all suggestion appreciated. TIA.
Thanks, unfortunetaly, I don't have Ellsworth's book (yet), and he doesnt' mention it on his DVD's that I have. I think I'm going to try that tonight, unless someone else has a better idea.
Went though this with HSS cutter blanks for my MiniMonster.
The little cutoff wheels are pretty fragile and don't take much torqueing to break - and fly off at speed. And unless you cut a little, widen the kerf and cut some more, they'll bind on the sides of the cut - and sort of explode. WEAR EYE - and better yet - WHOLE FACE PROTECTION.
Scribe around the blank and then, as suggested, put it in a metal vise and hit it with a hammer (clean the floor in the vicinity because the free piece will try and hide from you).
Someone told me to use my grinder by using the corner of the wheel and put a small "V" cut on each corner of the cutter. Then put in a vise or sharp edge line up on the "V" cuts and hit the other side. I did this once last year and it worked.
I use a little cutoff wheel on my dremel to score about 1/3 of the way through and then flip it to score about 1/3 on the other opposite face. From there, it's pretty easy to break by holding in a vise and using a vise grip with just a little bit of pressure.
The vise should be holding the bit about 1/8" or so below the cut lines. You grip it very close to the score lines and bend towards either cut. Requires no real pressure, and you only have a little bit of the metal exposed. Never had one "explode", but eye protection and gloves aren't a bad idea. The reinforced wheels also work better than those cheap one and don't shatter unless you do something really stupid...
I just score all 4 corners with the little cut wheel. Then it breaks very easily and evenly. I lay a towel over it so that when I hit it with the hammer it doesn't fly.
I've also scored the corners with a triangular file which works almost as well.
I score the corners lightly on the corner of my grinding wheel. I then place the scored cutter inside a small baggie. I the use the vise and a hammer to break it in half. The baggie contains the 2 parts.
Thanks all, I'll let you know how well it worked tomorrow. If I remember. My wife informed me I forgot to lower the garage door after I left for work!!!
... and put a small piece of duct tape around the bit after it's scored and in the vise; I then snap it off with a pliers or small hammer. I've never lost any pieces, since the duct tape keeps any loose pieces in control. I might have to try that baggie thing....
"If the the women don't find you handsome, they should at least find you handy".....
