WISH Box Idea - Part Two - Go With The Flow
charlie belden
Go With The Flow
Ya ever have a piece you were supposed to make? And as you make it - it develops a mind of its own? And you go with the flow - not knowing where it'll take you?
Jennifer's recent posting of some of her neat Wish Bowls triggered an idea. Combine her idea with a Drozda type lidded box that had a concave base. Put a small ball in the concavity of the lid and a few more inside - and they can roll around as you handle it. Take the lid off and you can get the balls inside the "box" to also roll around - slow or fast - you decide. Hold the bowl and rock it - and the balls inside will roll back and forth. If you rock it right, the balls will spin into "orbitals", rising up the side of the bowl the faster you move it.
So I "drew up" the basics of this thing in a primitive CAD program and a week ago I posted the illustration here just to throw out an idea. No good deed going unpunished, it was "suggested" that I actually make one - like THAT was going to happen. I had access to a laser engraver and THAT was going to fill my To Do List for a while.
But sometimes The Universe seems to change one's priority list.
I'm out in the shop "rearranging things" to work on the low relief "carving" samples I'd lasered ( "rearranging" involving cleaning off some bench top surface area to put the samples on. If your shop is like mine, you know that this means making space for the stuff that has to be moved, which, in turn means moving other stuff to make room for the stuff you have to move, which, in turn means moving . . .).
During the "rearranging" process I found a hollow form I'd started - and abandoned due to a crack that developed in the rim.
Hmmmmm. I'd only hollowed right around the rim so there was plenty of wood below that.
Hmmm. If I turned off the top part - I could make it into a flat topped rocking bowl. I'd already done a flat topped, undercut rim bowl
Hmmmm.
And one thing has lead to another - The Universe / Muse. I'd already done a flat topped, undercut rim bow, "why not add THAT idea?" the Muse asked.
Some reshaping, some undercutting, some hogging out the middle a bit. And as long as I was undercutting, why not turn concave "steps" up the inside for the balls to roll in?
As luck would have it, a former Significant Other had made me a small leather pouch - with marbles in it - fearing that I might Lose My Marbles otherwise. And, as luck would have it, I'd kept it all these years - AND knew where it was. MARBLES!
It seems that listening to your Muse works - at least so far - see!
Here's where I think The Muse will be going - or not.
As another indicator that The Universe / The Muse is to be listened to - I bought two sets of the Tekna Tools turnable plastic jaws - a year or so ago. Never used them - 'til this idea required them. NOW I understand why I "had to" get them ; ).
I like the troughs to hold the marbles. Lookin' more and more like a Roulette wheel. Well kindasorta
