Nova 3000 problems
Nova 3000 problems
Nova 3000 problems
Starry S Chan
I have a Nova 3000 with a Leeson 1HP DC motor and variable speed control. The lathe speed is 2160 when the variable control is set to 100%.
If I set the variable speed control to 30% and started roughing some 6" to 8" bowl blanks, the spindle will repeatedly slows down and return to original speed. This does not seem to happen when I set the speed higher. I guess that either the motor is stalling or the belt is slipping. The belt is tensioned with a 1/2" depression in the middle when pressed. Therefore, the belt is not very tight at all.
Is this normal?
TIA for your sharing of your experience with this lathe.
Starry
Re: Nova 3000 problems
D. Hansen
Have you set the resistors in the control box correctly. At a low setting of the control knob you will get a reduction of torque. That is normal. One way to overcome that is to change the belt position so you can run the control knob at close to 100%. If the resistors are set properly when the knob is fully counter clockwise the lathe will almost stop.
Russ Fairfield
Sounds like you are runningout of torque and horsepower at the 30% setting. You may need either a bigger motor or move the belts on the pulleys so the motor runs at a higher speed.
I agree with both. I had a 1 horse DC motor on my 3000 and anytime the power was set below 50 percent I could stall it easily. If you kept the original pulleys you should be able to change the steps and get more power. That is why the Variable Frequency Drives with 3 phase motors took over from the DC. You don't have the same power loss when you go to the lower speeds.
On the 3000 it's best not to tension the belt too much. This increases the likely hood of the motor shaft breaking over time.
arkie
I am not familiar with Leeson drives, but this is a common occurrence with DC drives. You can take a look at the adjustments in the drive itself. If you see a setting labeled "IR" or "IR POT" you can try adjusting it - maybe 1/4 turn at a time with the power turned off. That miht give you some relief. If you don't see the adjustment, just forget I said anything.
Starry S Chan
Thank you very much for your suggestions.
I change the belt to the pulley step delivering a speed I am comfortable with when the variable speed is set between 75% to 100%. The stalling problem goes away. This works so much better than putting the belt at a higher step and then using the variable speed control to reduce the speed.
As for belt tension, I used to tension the belt tight but I experienced excessive vibration. After some research, I found out that I do not need to tension the belt so tight. A half inch of depression when pressed at the middle of the belt works fine.
I am now a happy turner.
Thanks again,
Starry
