THE WOODRAT IS BACK!
velvet oil on salad bowls
joazhill
Hi all, I really like the ease of using velvet oil. However, i have never tried it on salas bowls. Can some one let me know if it is ok to use kitchen ware.
Thanks Joaz
www.maine-web.com/woodturning
Re: velvet oil on salad bowls
RK IN Milw
Velvit Oil (spelling is correct) is FDA certified as food safe.
Re: Hi Joaz, a question...
joazhill
Hi, it is actually spelled velvit oil. If you google it, you get the the manufacuter's web site.
Barbara Gill also uses it. It does seem to be very easy to use.
Re: Hi Joaz, a question... *LINK*
Carole Valentine
Barb is a distributor for Velvit Oil
Velvit Oil
R Payne
The FDA doesn't certify anything as food safe. It doesn't certify anything. The FDA regulates things. If you poke around enough you can find a big long list of chemicals that the FDA allows in finishes for use on work that has food contact. Any finish that uses only the chemicals on that list is considered non-toxic when fully cured. As far as I know, all modern finishes are non-toxic when fully cured. I have never been able to find any "food safe finish" according to any government agency. That is I haven't found any listing on any government website anywhere that said "food safe".
What all of this means is if you buy a can of finish off the shelf and any store it is likely safe to eat off of when it has fully cured. Some finishes (such as raw linseed oil) can take weeks to fully cure.
ron
Carole Valentine
The finishes are probably safer than some of the food we put in the bowls!
Re: The FDA Regulations *LINK*
Russ Fairfield
In 1978, the Consumer Product Safety Commission (CPSC) issued a directive that no paint or clear finishing product would be sold that contained lead or cadmium. A few specialty industrial coatings and some artists pigments are exempted from the directive, and they are required to be labeled as such.
You can read all about the "regulations", and what they mean at the link.
"Food Safe" Finishes and the FDA Regulations,
Carol Reed
OK. That made me laugh.
You are most likely too right!
Barbara Gill
Hi Joaz. I never checked the computer yesterday which is very unusual. Yes, Velvit Oil is food safe when cured. I use it all the time on my bowls. In fact I have been using it for over 15 years.
joazhill
Thanks all, I knew I could get answers here.
