Turning cabinet knobs / drawer pulls
Chris Hoehle
Greetings all, I've been a long time follower of this forum and have learned so much from you all so I thought I would post this and see what you have to say. I mostly turn hollow forms and bowls, so this is somewhat new territory for me.
What method do you prefer to turn cabinet knobs or drawer pulls? I've got some of the #8-32 brass threaded inserts and so far, I'm thinking I will start between centers with a 1 1/2" x 2" or so blank, turn a tenon on each end, then put one end in the chuck and drill my hole for the brass insert in the other end. Then, I'd flip it around and put the other end (now with the hole) in the chuck, finish turning, and part off.
The other idea that occurred to me would be to make a mandrel by bolting an #8-32 screw through a piece of plywood attached to a faceplate.
Are there any other methods that you like to use that might be more efficient?
