Veritas - Innovation in Tools
Salvaging Pepper mill parts
I have never made a pepper mill.
I have an Old Thompson mill I like. Not much to it. A sort of acrylic Square tube. Just a "stick" about an inch and a half square and six inches tall. I have tried other mills including what appears to be identical mills from Old Thompson, But this one is the favorite. Just like the way it grinds.
The problem is that the acrylic is failing. Cracked and getting worse. So any chance I could salvage the mechanism and make my own pepper mill to put it in?
Re: Salvaging Pepper mill parts
Bill Howatt
Probably as long as the mechanism can be removed easily by a few screws - that is, it isn't somehow riveted, crimped, welded, brazed, soldered etc.
You'll then have to duplicate the inside openings to accommodate the mechansim. The opening the crush mechanism sits in needs to be fairly close and the height will need to be close because of the length of the shaft to the knob you twist. Other than that you'll have some design latitude.
Bill
