First Try At 3D Laser Engraving
charlie belden
O.K. - so I didn't get as much done as I'd hoped but I did get two 3D laser engraved samples done.
Having to deal with WINDOZE didn't help, nor did having to work with COREL DRAW slowed things WAY down. Once again I was reminded why I didn't like COREL when they made a version for the MAC OS - the interface is not very intuitive and when you find something that looks sort of familiar - like CROP - it doesn't work like that function does in other graphics applications. Just finding my FLASH drive was interesting.
But once I had one of my GrayScale test images opened in COREL, getting it to the laser and doing the lasering was a No Brainer - works as though it's printing to a normal printer, with a few parameters unique to laser engravers - Speed (how fast the head moves), Power (how much of the laser's max power is used for each "shot") and Frequency (fast the laser fires). The "printer driver" translates the data to something the laser can understand and use and sends it the the laser's memory. Press the GO button on the laser and it starts burning.
The actual laser burning is sort of like watching paint dry. And if you feed it a 600 DPI image that's 5" wide and about 8" long it takes a while to complete - say 15 minutes. BUT - compared to freehanding - with a pyrographic pen - it's lightening fast (after you've created your image file of course).
Redwood was probably not the best wood to test on - but the results were interesting.
What I see with doing laser engraving and laser low relief sculpting is low risk - graphics software has an UNDO feature. I also see it's ability to enable nuances - subtle things that are very difficult or nearly impossible to do with even the finest pyro tip - AND good eyes along with very fine motor skills. The laser brings capabilities and possibilities that either weren't possible, or would involve a VERY steep learning curve with LOTS of hours and hours of practice. And even a relative novice with graphic software can now do things he/she wouldn't even consider before.
So here's the results and the gray scale images that created them.
More later if there's an interest.
Re: First Try At 3D Laser Engraving
Jennifer Indy.USA
Cool Charlie! Keep going!
Bill Neddow
That is really interesting, Charlie. I can see all sorts of uses. What sort of a laser system is it? Is it expensive?
charlie belden
These were done with an Epilog Helix - 45 Watts, and not in most folks' price range - in the $11K range - plus exhaust ducting required - and a small compressor to blow air over where the laser is burning. This one is available at The Saw Dust Shop in Sunnyvale, California - in a FULLY equipted shop that also has a Shop Bot AND chain link fenced storage area for people who pay for membership to use the shop. Full unlimeted access membership runs about a grand a year but for a lot of woodworkers it beats working in a one car garage with contractor's saw and maybe a bandsaw.
Though I've got a four car garage shop, all the stationary tools, power tools and a load of hand tools, I probably wouldn't put a laser on my wish list. BUT - having won a life time membership, the only thing I'd ever won was a CB radio - to give you an idea of how long ago THAT was - seemed like I was destined to play with laser engraving.
Laser engravers are becoming more accessible and there are places that will take your image file and chunk of wood and laser engrave it for you. I suspect Kinkos and copy centers will catch on at some point so more people can use them for things we can't imagine at the moment.
Wizardry,
Jorge Casta�eda
Fascinating, wish there was something similar around here.
Keep going and thanks for sharing
Jorge
Steven Antonucci
OK, so how does that work in the round?
steven antonucci
I could see using it to burn a pattern that went around something, but it appears to be more applicable to flat surfaces. How can this be applied in the round?
Aside from being cool (LASERs are very cool!), where does this go?
Steve
Re: OK, so how does that work in the round?
Doug Thompson near Cleveland
They sell rotary attachments for the round stuff.
Re: OK, so how does that work in the round? *LINK*
charlie belden
Well, for turning, you get yourself
- a foot or so long piece of 1" x 8 TPI AllThread (about $16 USD fora three foot piece - share the stuff with a couple of other turners),
- a 1" ID x 8 TPI adapter to fit your scroll chuck or face plate so you can mount it on the end of the AllThread (these puppies are expensive for what they are - almost $40 USD for my JET mini)
- three 1" x 8 TPI nuts
- an Indexing Wheel you can make, or buy for about $25 bucks
Then make a ply box tall enough to have the center of the All Thread shaft no higher than 6" for the Epilog Helix Laser Engraver since it can only handle things up to a bit over 12" tall (or for us, 12" round).
I added a TILT feature on the one I did but a couple of separate wedges would work too.
Because the laser has a limited effective depth of field (about 1/16th inch), the "working area" for it varies from about 1 square inch for a 2" D curve to almost 2 square inches for an 8 " D curve, hence the need for an indexing jig. There's more about all that at the attached link.
The creative part of laser engraving is doing the art work you'll use. Sure, you CAN use a digital photo, clip art that's readily available or stuff you scan. But the FUN! is doing your own artwork using software you probably already have - software to do it comes with most digital cameras and scanners these days. I use Adobe PhotoShop 5.5 on my old Mac G3 and Elements 6 on my newer Mac Mini.
Here's an example of a way to create a GrayScale laser pattern
I'm playing with ways to draw gray scale ideas using a combination of "air brush", "dodge", "burn" and "smudge along with "blur" tools in APS.
Doing the artwork for lasering is where the creativity can come in - and the possibilities are endless. The laser, well it's just another tool to use - a Photonic Chisel as it were - that only does what YOU "tell it" to do. The art and skill all comes during the making of the image to be used - and that's up to you.
Will post what I find as I find it. If others have experience with laser "carving" PLEASE jump in and share what you've learned.
Indexing Jig and Effective Working Area
Steven Antonucci
Only one problem solved there...
steven antonucci
You are dealing with a round surface. I suspect that the laser has a range of motion that covers a large area, but your distance at the outer edge of the vessel will be substantially more than the centerline, no? I may have it wrong that the laser has three degrees of freedom, but I am assuming it moves in a plane.
In addition, I don't know how you will acomodate the flat to round image conversion without knowing the exact curvature of the vessel. To have the image appear "normal" I'd imagine you'll have to curve it to fit the surface somewhat?
Whole lotta math coming your way...
Still, laser are cool...
Steve
Re: Only one problem solved there...
charlie belden
Steve:
I'm not after a continuous pattern all the way around a piece - though that CAN be done, as shown at the attached link. And given a longer radius, and a small pattern, distortion isn't an issue.
What I have in mind is "carving" 3D patterns on intersecting arcs piece - two and three center stuff. This will given me longer radius surfaces and thus more "effective working area" to play in.
As for any math, cord lengths aren't hard to calculate - I'll know the radius of the arc, having scribed them on the ends of the blank.
Still need to do some test samples on other woods - have three 2 arcs pieces in walnut to work on and several fruitwood bowls I never fiinished to play on.
What I NEED is a Mac version of Corel Draw since that's the software Epilog supports and there are laser engraver forums where most folks use Corel Draw.
Will keep you posted on progress.
Steven Antonucci
My completely different vision for the technology
steven antonucci
I had it competing with rose engine work... I have a project in my head (for years now!) that this might have been a workable solution...
Did I mention that lasers are cool?
Thanks for pushing...
Steve
Evocative Motivator
charlie belden
Push, pull - beckon - I'd prefer to think in terms of Evocative Motivator.
Yes, lasers ARE cool - figuratively. VERY hot literally.
3D sculpting and carving software is out there but the learning curve is a bit steep - at the moment. Google's free SketchUp 3D software may just help ease people into 3D grayscale image making for laser carving. And, compared to learning to use a Rose Engine / Ornamental Mill, 3D virtual models give you a pretty good idea of the finished piece - BEFORE you get to the wood. Bits and pixels are easily replace. A nice piece of wood - not so easy to replace.
Sources of images to play with and tweek are on the web. Hubble images, converted to gray scale hold out plenty of possibilities to experiment with.
