The honing of the skew...
Scott Burr in Ben Lomond CA
I'm getting ready to put an edge on my Doug Thompson skew.
How for do you go in honing it?
I've seen people stop at 320 grit and have read some go to razor sharp.
How do you do it?
Re: The honing of the skew...
Steve Kubien
Steve Kubien
I think that a medium or fine diamond hone is good enough for turning. For DMT diamonds, I think this means around 320 and 600 grit respectfully but I may be wrong.
I always guffawed at turners who said they sharpen their gouges really fine...on a 120 wheel. Of course, I was coming from a background in handtools (like you are) and it took me a while to realize they ain't the same. There are no mirrors in turning like there are in handtools.
Jennifer Indy.USA
It's the only tool that I hone and I use one of the credit card style diamond hones. The Red one. I think that's medium? No idea what grit it is?
Jen
Lance Kanaby
Skews need to be really sharp and that means honing. I showed one of my students how to sharpen a skew and then hone it. He asked how long do I hone it and I told him when he can shave with it. I am not a big fan of the Tomek System for sharpening turing tools because it takes too long. It does do one of the best jobs on skews right from the wheel and you can take it up a few more notches with leather honing.
Scott That's the one tool that I really sharpen. I use the EZE-Lap diamond hones. I start as course as necessary but usually straight off the grinder I can use the purple medium hone. it's about 320 grit. I hone one side until you can feel a burr on the other side. Then I hone the other side until the burr is raised on the back side. Then I go to the fine which is 600 grit and then to the ultra fine which is around 1200 grit. This is usually enough and will shave hair but if it's a difficult wood I strop it with leather and the green bar from Lee Valley. You can really feel the difference in the cut.
If you strop it every few minutes it will stay sharp for a while. The same is true if you stop at the ultra fine. The more often you hone the less time you have to spend.
The skew is a tool that works better when you apply very little pressure while using it. The only way to use very little pressure is to have it very sharp. You can apply a lot of pressure and make it cut. On flat cuts this works. When your turning beads and yes even coves then sharp and light pressure is so much easier to control.
The honing of the 1/4" round skew...
Ed Moore in SW VA
is easy on a piece of 1200 or 1500 paper. After I touch it up on a wheel I simply put a piece of paper on a flat surface and drag each side across it. Two or three strokes is all it takes. Of course this is the good maroon wet/dry paper from Portugal that I get from SuperGrit. For this purpose it is better than a diamond hone.
Respect the bandsaw,
Ed
Steven Antonucci
Three easy steps
steven antonucci
Step one is the grinder (I use a Tormek). It is better than a slow speed/high speed grinder in terms of the edge you get, but I still do two more things.
Step two is a diamond card. If you are using a SS/HS grinder, I would refine the edge with DMT red (600, I think) first, and then DMT green (1200, I think). It only takes a couple of strokes on either side, and you will see a noticable difference at the edge.
Lastly, I hit the edge with a strop with some white diamond or the yellow stick that I used for carving tools. That final hone give me a shaving edge.
I can usually renew the edge 2-3 times with the strop before I need to go back to step two. When I go back to step 2, I usually only need the 1200 grit green file, 1-2 strokes either side, and finish again with the strop.
(Thie works on all of my tools, not just skews)
Steve
Bill Grumbine (Kutztown PA)
At the risk of causing someone to faint in horror...
This is how I have been doing it for years. What you do not see in the video is grinding the initial bevel on the bench grinder, but once that is done, you can see the entire process.
Slight thread hijack - plane question...
Mike Rubes, Apex, NC
Hi all,
Great information on the skew honing. I've never had a lot of success with the skew, maybe I just don't have it sharp enough.
Just curious for those that also do flatwork, do you use this same procedure to sharpen your plane blades? I use the "scary sharp" sandpaper sharpening method, but then never hone. Just go straight from superfine grit to the wood.
And in the mind set that the only stupid questions are the ones left unasked, when you use a white diamond compound to strop, is that the same white diamond stuff I use as the mid-step on my Beall buffing system on the lathe? I think the answer is yes, but would like to hear from someone who actually knows! :)
Thanks,
Mike
Almost done with the stereo cabinet and ready to turn something in Apex, NC!!!
Re: Slight thread hijack - plane question...
Mike I also use the scary sharp method but I do strop as my final step. Sharpening plane irons was how more or less how I learned to sharpen the skew.
David Walser
Bill,
What was it about your video that you thought might produce horror -- the way you sharpen your skew or the fact you pack heat while turning? Neither caused me any concern, by the way. Well, I've never worn a gun in my shop, but only because I'm afraid it'd get in the way. For the same reason, I don't wear my cell phone on my belt when in the shop. Whenever I forget, the phone will get ripped off my belt and land on the floor when I fail to leave enough room when walking past the grinder, the vise, the bandsaw, etc. I'm pretty sure the same collisions would occur if I had my pistol strapped to my waist.
David, you must have missed all the excitement the last time that video got posted. I will write you privately about it.
Thanks Bill...umm...yea...
The video was great does the sidearm keep the lathe in line? Or stop distractions that one encounters while turning? :O
Thanks again!
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA---
I'm surprised that no one has mentioned power honing. I won't describe it because there's plenty of information out there on just what to do. Allan Lacer describes it very well, for example.
Hi Mike,
I'm using a mix of water stones and SS.
I just got finished with mine and took some pics. I'll make a new post soon. I'll get to see if I (we) got it right or if we need more help...
One of my favorite quotes from Blazing Saddles:
Sheriff Bart: "Do you need any help?"
The Waco Kid: "Oh all I get"
Cheers!
I have a Sheppac wet wheel grinder with a leather strop on one side. I frequently use that as the last step for the skew. It's about 10 feet from the lathe so it gives my feet a break to walk over there.
Jorge Casta�eda
Hi John,
did a search for the Sheppac wet wheel grinder and came empty. Could you give more info? Sounds like a good system.
Thanks
Jorge
Apparently I can't spell  *LINK*
It's either a copy of the Tormek or it came first and Tormek improved on it. I don't know. I got it really cheap from a friend so I thought it would be worth trying. The Jet and Grizzly are obviously knock offs of the Scheppach and/or Tormek.
It works pretty well. I looked on the net after I got it and the only complaint was that the wheel slipped. It's just belt driven so I added a spring to tension the belt better and I'll bet it's as strong running as the Tormek now. You can't hog it down.
It's definitely not in the same leaque with the Tormek. I think many of the accessories for the Jet may fit but I haven't tried yet.
It was worth the money I spent but it's not a great machine. I use it to salvage old plane irons and put an edge on them. I'm also going to use it to establish a good edge on carving tools. I use the leather strop wheel the most.
http://www.amazon.com/Scheppach-Vertical-Grinding-Sharpening-System/dp/B000BOLGE4
Re: Power honing of the skew...
Russ Fairfield
Power honing is the only way to do it, and it hasn't been mentioned because I had yet to post a message. I do a lot of spindle turning for furniture and piano restorations and I keep both skew chisels and spindle gouges sharp with a very hard felt wheel and the green metal polishing rouge that is about the equivalent to 800-grit.
There are also flat discs that are attached to the spindle of a drill press, and they work very well. There was a home-made version in an old Woodsmith magazine of at least 15 years ago, that worked very well.
I grind a fresh bevel that is flat, and with about 25-degrees between the bevels. Over time the buffing wheel gives it a slightly convex curve similar to that on a carving knife. I go back to a flat grind 3 or 4 times a year when the convex curvature starts getting too large.
I also use a trick I learned many years ago. It isn't an elegant solution, but it works to keep the tools sharp, and it costs nothing. That is leaving a short oversized round somewhere near one end of the piece of wood, melting some tripoli into it while the piece is spinning, and I can keep the skew or spindle gouge sharp with a quick honeing as it starts to get dull. It only takes a few seconds; and I never have to leave the work or disrupt the rhythm of the turning. The only thing to remember is to roll the tool over for honing, but there is no danger if I forget to do that. The honing wood is removed with the last cut, and the tool has a freshly honed and sharp edge for the next piece.
Thanks John
Jorge Casta�eda
