Building a 13" hand beat drum - questions
ebd
ebd
I bought the hardware but I'm lollygaging on buying the wood and getting started. For wood I'm thinking of using either wenge or zebrawood. I've calculated 2" as the top of the stave for 15 degree/12 stave segements. I'm afraid to proceed as I'm not sure I'm correct. I can make trial cuts to make sure of the exact dimensions.
The biggest problem I have is that I have no idea how deep to make the shell nor how thin to turn it. I would like to get the largest range of tone possible but keep it on the deep end.
If anyone has any suggestions they would be most welcome.
Re: Building a 13" hand beat drum - questions
Stuart Johnson
Use plywood to make up a sample. Go ahead and not only cut the starves but assemble and turn it. You can tell if you have any problems plus you might just find the plywood drum is nice looking.
Bill Howatt
Aren't there any forums about drums and drum-making to give you ideas on dimensions?
Since this obviously is a first attempt, I'd certainly do it with cheap wood as suggested to get the kinks out of the process.
Bill
Matt Birchfield
To get the best tonal quality and range, build your drum with the hardest wood you can find (to bounce the sound waves rather than absorbing them), keep the walls thick (to maintain range and sustain of the sound), and make the inside as rough and irregular as possible (to make the sound waves bounce irregularly, making the tonal quality better). Use an equatorial goat skin for the head because they're very thin and very tough. Another way to make the largest range of sounds is to make the head bigger. Keep these things in mind and the drum will sound GREAT!
ebd
ebd
Thanks Matt. Good info. I'll be making a few prototypes from pine till I get the process right. I'll post a picture once I get the final version done. Probably several months from now as soccer is starting this sunday and a week from thursday I start in pool lessons in SCUBA.
Matt Birchfield
Hope it helps! Pine drums will sound good too, and will be fun to play... until you get to the first hard wood one! Have a blast!
