Wood Burning Tool
Larry
What is everyones favorite woodburning tool?
Thanks
Wood Burning Tool
Larry
Thanks
Re: Wood Burning Tool
Steve Kubien
I built a Priddle burner (with lots of help) and it was hot and fast for branding. Kind of useless for fine lines. Anyway, it died somehow and being electrically challenged, I have no idea why. SWMBO bought me a Burnmaster Eagle for my b-day and it is a treat! Amazing control of the heat for soft or heavy burns. I haven't branded with it yet but Molly steered me towards this unit because of the style of work she does so I know it will perform.
Richard Allen
Detail Master has worked great for me. I have not heard bad things about any of the different brands of base units.
For fine detail I like the razortip pens. For more heavy duty burning (not branding) I like the Detail Master pens.
Taking a one day class from a talented teacher will teach you a ton about the process.
fgvanatta
I use the Colwood Cub; very versatile and easy to use - I've been happy with it.
Allen Neighbors
My woodburner made from a 6/12 volt battery charger, and the Molly Winton pack of Nichrome wire....
Just to throw something different into the Mix. I bought the Optima after using a Colewood cub for several years. The difference in burn quality was like the difference between a dull tool and a sharp tool. I think it would be hard to go wrong with either the Burnmaster or the Optima.
Matt Overton
I agree. The Optima is a quality tool.
Don Pencil
I went with the battery charger and it does everything very well.
Jennifer Indy.USA
I bought the Optima first a few years ago and I like it a lot. What I love most about Optima though is their burning pens. All fixed tips, great heat resisting grips and if you buggar one up you mail it back with $5 and they fix it. After playing with burning on my work for a couple of years I wanted something that got hotter that would be better suited for using the home made brands and thicker wire. I bought the Burnmaster dual port and am very happy with it. It is my go to burner now. Last summer I made the Priddle burner out of a NAPA Auto Parts battery charger and it has now opened up new avenues for deeper branding and new textures with even thicker wire. If you go woth the Priddle style burner just remember it is not for doing light, fine lines. You'll need an alternative for that.
Jen
