With my fool's cap on, and making a wishful assumption that fulfilled a dire need for new hex shaft pad holders, I order 2 from one off the really big names in turning. Little did I realize that 8mm hex shafts would not fit a singe one of my 1/4in. chordless drills. Ugly! Zero response from the seller so back they go in the morning mail.
I really wish one of the turning tool manufacturers would make pads with the "Snappy" (reg TM) style of hex shaft. Being able to just pop them in and out rather than having to mess with the chuck each time would be great for those of us that use a holder for each grit. But they would have to come close to Industrial Abrasives' prices, maybe a $ more, to get my interest.
The hex shaft holders sold by Craft Supplies work in all 1/4" holders I have, and measure 0.25",0.25", 0.24" and 6.4mm, 6.4mm 6.3mm.
As I recall the IA holders are $5.50 and $6.50 and the CS holders are $9 and $10.
CS holders use the micro velcro hooks like Vince uses. These hooks are less susceptible to heat degradation than the hooks on the IA pads. An interface pad can be used on the IA pads to eliminate this slight advantage.
Personally I am fine with the IA holders. I have no issue with pealing sanding discs of the holder and sticking a newer finer grit on. I purchased the CS holders to keep a different grit on different holders. But I generally discard a disc as used with each turning.
Definitely read the fine print, or the hidden print. I Googled to find a Nuvi to replace the one I gave to my Daughter. Up came a link "Garmin Factory Outlet Store". Being a trusting soul (read Dumb Shit) I ordered. Fortunately their BS ran to shipping times as well. I cancelled the order after 4 days and the purchase hadn't been shipped. Turns out they aren't associated with Garmin in any way shape or form. Their web page did say that, just a tiny bit below, and in a tiny font, in a place that you would never notice. The right (vertical) scroll bar was so far full that no one would bother to scroll further down - I thought it was obvious that the whole page was on screen. Their webmaster must have just miscalculated on size. My mistake. The notice was in that tiny space. Their return policy is replacement only. And their products are almost entirely rebuild, and "may contain small blemishes or imperfections". All this at a price that was a huge $5 less than a new unit. I will NEVER not read the fine print and search every inch of the website again.
