Three Wishes
Three Wishes
Three Wishes
Jennifer Indy.USA
Hi Gang,
Here is another one of the Wish Bowls that I've been playing around with for the last several years. Most of the ones I've mad previously are relatively small in the 3-4" diameter range but this one is a bit bigger. It's about 6" inches around and about 3" tall. It's textured with a squiggled piece of 16 gauge wire in my Priddle burner and then covered with black milk paint and then filled with tile grout. One of things that I love about Milk Paint over cherry is the beautiful color it turns the cherry when you rub through the paint. I'm not sure what causes it but when I assisted Al Stirt's class last summer he said there is something in the milk paint that interacts with the tannins in the cherry to cause this. It almost looks bronze when you rub through it. The final finish is spray Deft matte. The three wishes are burned with my standard burner. I think I may do some more in this size. They are a bit more dramatic in this size I think.
Thanks for taking a peek!
Jen
Re: Three Wishes
Mike Stafford
Re: Three Wishes
Mike Stafford
This is a very dramatic bowl, Jen. The decorations of the bowl almost make one lose sight of the balls inside. Very pretty. I like the texture of the black wish ball.
Next you can do wish bowls on pedestals and wish bowls with lids and emerging wish bowls, you know bowls turned from a solid block and some of the rectangular block remains.
Re: Three Wishes
Re: Three Wishes
Cyril Griesbach
Very will done, Jen. We haven't seen one of these in a while.
Re: Three Wishes
Re: Three Wishes
Barbara Gill
Very nice Jennifer.
Re: Three Wishes
Re: Three Wishes
Bill Neddow
Absolutely gorgeous! -- as are the smaller ones in the other post.
Re: Three Wishes
Re: Three Wishes
charlie belden
Your wish bowls are wonderful in so many ways. They trigger a child's wanting to play with them. They draw the eye into them. They draw the mind and evoke emotions. They set turners, newbies as well as old hands at turning, thinking "Looks like fun. I'm going to try one!" They beg the question "How did she do that (fill in a detail or two)?".
And best of all they spark the imagination - If I Had Three Wishes . . .
Re: Three Wishes
Re: Three Wishes
keith zimmerman, Normal IL
This is lovely. I'll have to remember about milk paint and cherry. I love the color. Did you seal the cherry prior to adding the tile grout?
keithz
Re: Three Wishes
Re: Three Wishes
Keith T
Hi Jennifer, I like this!
Re: Three Wishes
Re: Three Wishes
Jennifer Indy.USA
Thanks Keith. Yes I always seal with something before applying the grout or a modeling paste filler. It just keeps the black or what ever color is on the bottom from getting mottled from the filler. It makes it easy to wipe off.
Jen
Re: Three Wishes
Re: Three Wishes
Jennifer Indy.USA
Charlie that's exactly the reaction I want from people!
Thank You.
It's no different from turning a big bowl.
Jen
Re: Three Wishes
More questions
I had another question about this Jen. What did you use to rub through the milk paint to expose the cherry, and when? Did you cover the entire piece with milk paint, wait for it to dry, then rub it off?
I really like that color you wound up with and want to try it.
thanks in advance.
keithz
Re: Three Wishes
Re: More questions
Jennifer Indy.USA
Keith you got it. I cover the piece with the milk paint. Sometimes two coats. Then I burnish or rub out with 320 or 400 grit. It will expose the wood underneath at the high spots and on edges. Then I use a sealer of Krylon or Deft spray. Usually matte finish. Then I use whatever filler I'm going to use. Then I'll rub all of that off good and seal it again and tend to do a final rub out with a softened up piece of paper grocery bag.
Jen
