One of my McNaughton knives has a slight flat spot. The spot is right behind where the knife widens out to full width and causes it to rub on the blank as i cut the core. I drew a set of concentric circles and checked out. Its about 1/32" "IN". I have beaten on it a bit with a ball peen hammer, but have not had much effect. Any suggestions?
Widen the kerf a little at the entry point as you core. That seems to be what all the videos suggest and it works for me.
It's a coring knife..not a precision instrument. I'm not sure I could even tell a 1/32" variation existed in my blades. I did have a couple that did not sit flat so I used a partly open vise and re-bent them so they were flat on the bottom.
I agree with Jeff, Barry. I would not think a 1/32 "flat spot" would even be noticeable, though I am not quite sure I know exactly what you mean by that. A hump on the outside of the blade, on the other hand, may be noticeable. Got a picture?
You are right, the knives should be concentric. If they aren't you need to widen the kerf, which wastes wood. Unfortunately the large set is made of spring steel and can't be bent. If you are talking about the standard set or smaller sets, they are made of mild steel and can be bent. Bending them to the correct shape helps a lot!
The blades often need fine tuning. On my tool rest, I have the gates/support fingers locked into place so they don't rotate (drill a recess in the ring the set screw goes into, and tighten it up), so I can fine tune it by putting it in the gate and applying some pressure. The main line up problem seems to be in the tips as they don't fit into the stamp, and tend to go straight rather than follow the curve. A minor tweaking here helps as well.
If your blades develop a downward arc, either from catches, or heavy use and abuse, this is a torque thing, and if you clamp the handle end in a vice and use a bit monkey or adjustable wrench, you can twist it back up into proper position.
