Possible "Micro Sander"
charlie belden
So I'm reorganizing a floor to ceiling bathroom cabinet and I come acrossed my old SoniCare electric toothbrush which was replaced by a New AND Improved SoniCare.
Hmmmmmm . . . if I were to cut off the brush part . . . it just might make a micro sander - light duty of course. These things come with multiple brushes so you could have a different one for different grits. You could use the cut off tip's small flat surface - or wrap sand paper around the shaft . . .
The "stroke" is really short but LOTS of strokes per second and not apt to break a delicate piece.
Conceivably, you could drill a hole into the end and have small insert files - say the kind Endo Dontists (the root canal dentist) use. Could get into REALLY tight places without much risk of damage to the piece.
AND - no power cord!
While the SoniCares ain't cheap, there are battery powered toothbrushes available in just about any drug store, or even in some grocery stores (remember when grocery stores just sold groceries?).
Anyone tried this idea yet?
Re: Possible "Micro Sander"
Terry Scott
No but I will be great idea
Carole Valentine
I used my recip carver like that one time to get up under a tight space - a small strip of thin metal held in the collet with some sandpaper stuck to it. Of course you have to pull and hold the collet back to get the action. It worked for the little bit I needed to do. I have used some weird stuff to sand in tight places! LOL
Juergen
Did that with an old Braun electric tooth brush a few years ago . I like them better for this purpose than the Soniccares. The Braun's brush rotates much like an orbital sander. I just glued a piece of H&L on the business end after removing the bristles. Then with a hole punch I made small, 3/8-1/2", disks of various grits.
Don Evans
Yep, been there done that. Was about 5 years ago. The bristles are easy to pull out as they are just seated in, not glued etc. Long nose pliers, just grip each bunch at bottom and pull them out.
I used double sided tape to stick sandpaper to the flat where bristles were.
It was ok but mostly learned that where it will go and the amount of work it will do was just as easy to do by hand with rifflers and very fine files.
It finally stopped taking a charge so I just tossed it out.
Don
charlie belden
I'm thinking root canal micro files stuck in a hole in the end of the cut of end of the "brush". These things are flexible - they have to be in order to do what they do - so they should be able to get in pretty fine piercings.
With a hook and loop stuck to the flat of the "brush" - after removing the bristles as you decribed - and with a little heat bending to put a curve in the "brush" they it could work on a piece like the Leaves piece Andi Wolfe posted earlier.
Re: experience five years ago - like so many things - electric toothbrush technology keeps changing. What was true five years ago may not be true today - the nature of our times. I may explore this idea later - laser engraving is up next.
