Thompson tool wear
This is a 2 part discussion on tool wear and sharpening. Many months ago Doug asked if anyone could measure how much of a tool is ground away with each sharpening. Well I can't answer that because I don't know how long I've owned my 1/2" bowl gouge or how many times it's been sharpened.
I know I've had it over 2 years and It's my favorite tool so it gets used a lot and consequently sharpened a lot. I sharpen it mostly on the Oneway Wolverine jig. Rarely do I hone it with the diamond hones although will sharpen the flute using a diamond fish hook hone when I need a really sharp tool. I have been using 100 grit white wheels at 1725rpm for sharpening these gouges.
A few months ago I purchase another 1/2 bowl gouge to be sharpened like the Michelson grind. It dawned on me yesterday that I could match the flute length and have some idea how much tool has been ground away. Of course this does assume that Doug had been grinding the flutes the same length for the last few years and only he can answer that.
I was amazed by how little metal has been removed. I do use a very light touch on the wheel and with my wooden jigs for setting the V arm of the Oneway my sharpening is very repeatable. I would guess just about as little metal as possible is removed each time I sharpen.
As you can see in the photo it's only a little more than 1cm. That's not very much considering how many times this thing has been to the grinder. The lower tool has only been sharpened a few times. I think that's pretty amazing considering that early on in my turning I ground away most of a gouge in year or so.
