Epoxy filling - what I used
Craig Daymon
I was turning a platter the other day and came upon a knot/inclusion that came loose and fell out. I filled it with some Gorilla 5 minute epoxy that I mixed with Irwin Strait-Line black chalk. The mixture came out very black. I can't say for sure just how well it worked as I haven't turned it true yet. I'm not sure if it is the epoxy or the combination with the chalk (which I thought would be rather inert, not effecting the epoxy at all) but the epoxy was taking much longer than 5 minutes to set.
Anyway, if it works, I thought the chalk was a pretty good idea for coloring the epoxy. The black is labeled as "permanent", so hopefully that means it will stay black. (There was also red permanent, but I didn't think it would work for this piece.) The price was $1.39 for 8 ounces. The graphite in the lock department was about $2.50 for probably less than half an ounce. (Orange box store.)
In getting ready to do this, I spoke with a friend who mentioned that he had bought a gallon of graphite powder at a Farm & Fleet store. (Since graphite is frequently used to color epoxy.) He wasn't sure about the price, but it was very reasonable. He said it is mixed with seed so they don't stick in the planting machinery. So, it might be something to look for next time your wandering through Farm & Fleet, or some similar store.
-Craig
Re: Epoxy filling - what I used
Re: Interesting, and thanks!
fgvanatta
I generally use India Ink to color epoxy. It takes very little, and doesn't seem to affect the epoxy curing time, final hardness, whatever.
Frank
Richard Allen
Richard Allen
I prefer the slow cure epoxy. I find the 5 minute stuff never cures really hard. Epoxy cures with heat so you might try warming the piece up a little. 110 F should be plenty of heat.
I have put well over 20% filler in epoxy with only positive effects.
Craig I use 5 minute epoxy all the time with various coloring agents. It takes a little longer to cure when you add very much colorant but has always worked for me.
Hi Frank...
Scott Burr in Ben Lomond CA
I use it "a lot" for ebonizing walnut and other dark woods. I figured it would water down epoxy. I'll have to give it a try!
mike
"Rudd" dyes from a local paint store and made for the automotive trade for tinting lacquers will give you the advantage of having color selection, and the ability to blend colors. They take these dyes from bulk and fill 2 oz. plastic bottles for a bout 4$ each.
mike jones in Redding CA.
The black chalk as filler worked well
Craig Daymon
There's still a good bit to do on the platter, but the black chalk worked well as a filler in the epoxy.
I may have to do it again before I'm finished if I expose any more problem areas or if I hit a substantial air bubble in the area already filled.
-Craig
P.S. My friend who mentioned Farm & Fleet for the graphite also mentioned he had used wheat flour as a filler with good success and he liked the resulting color. I haven't tried it, so I can't give a personal opinion, but it sounds like it might have a good color match for the maple the platter is turned from.
