Mini-lathe Coring Tools
Doug in Seattle
Doug in Seattle
I have a Jet mini-lathe and some really nice green cherry that is pretty thick. My usual method leaves a lot of the wood on the floor as shavings. Is it reasonable to use a coring tool on a mini-lathe to save some of those shavings as bowl blanks? If so, which brand/model will work for such a small and maybe underpowered lathe? I just hate to waste so much of the wood to get one bowl.
Re: Mini-lathe Coring Tools
Greg Haugen
Doug, the answer is yes. Here's a link to Mike Mahoney's Site. Click on his "blog" button and look at the third post down.
www.bowlmakerinc.com
McNaughton makes a Micro version. The Micro does have a 5/8" post. Oneway makes a system for 12" lathes, if you have a 12" Jet. Woodcut does have a system as well but I'm only seeing it in 1" posts.
As far as which system? Personal preference and budget. The McNaughton systems are more versatile and the Oneway/Woodcut systems have a shorter learning curve.
No matter what, make sure the system is set up correctly, at the right height, and take your time. It can be done though.
Richard Allen
Richard Allen
The bowl saw is what you want.
Jeff Rich
I think Steven Russell has a method for coring when using low powered lathes.
His method uses the McNaughton tool, but would apply to just about any coring tool.
robo hippy
The McNaughton is the only coring system designed for mini lathes. For the other systems, you need about 1 hp. I have the Oneway system for a 12 inch bowl, and don't really like it. I think the Woodcut is a lot better, and the biggest core you can take with it is about 11 inches. It does cut a bit easier than the Oneway, which only has one blade, while the Woodcut had 2. The McNaughton does have a learning curve. There are 2 DVDs showing how to use it, mine and Mike Mahoney's. You need one of them, or find some one in your club who can use it and let them help you. It isn't easy to just pick up and use.
robo hippy
