clear finish
clear finish
clear finish
eliot d
Is it fairly well established that the most clear finishes are the water-based ones? I turned a vessel out of a kind of spalted maple that really turns dark yellow when finished with the usual stuff. Which finish would tend to preserve its light color the best?
Re: clear finish
Re: clear finish
Greg Haugen
Eliot,
When I turn walnut vessels or boxes where the end grain is going to be showcased and I don't want an oil that will turn it black I'll use a couple of Krylon finishes. This is something I've learned from a John Jordan article. Krylon's Matte Finish will work if you want a matte or satin finish. The finish can be "fussy" in the fact that it will turn white (like frosted glass) if applied to thick. It's a good finish but take your time and "mist" it. Recently I used Krylon's Crystal Clear Finish. It's acrylic and comes in a few sheen options. I "soaked" a test piece to see if it would turn white like the Matte finish, it didn't. The walnut still had it's natural beauty without being overly dark.
Spalting lines can sometimes "run" or "smear" if they get too wet or have an oil finish. Light coats will be the key.
Re: clear finish
Re: clear finish? Try Deft Acrylic.
Russ Fairfield
The new clear acrylic from Deft will impart the least color of anything that I have ever put on a piece of wood. There is even less color that wetting the wood surface with plain water, and it is available in 3 levels of gloss.
Re: clear finish
What Russ said . . .
fgvanatta
Re: clear finish
Texian
Russ, Do succesive coats of the acrylic bond/melt together in the same way as other lacquers?
Re: clear finish
Russ Fairfield
No, this is not a lacquer. To get a waterborne lacquer with burn-in you will have to go to Target Coatings or the Stewart-McDonald catalog. There may be others, but I am familiar with these.
Re: clear finish
Texian
Thanks Russ. Am mostly using the Deft rattle can lacquer (which does not rattle); sometimes build first w/ brushing lac. B4 spray finish coats. Still plan to try your trick of airbrushing w/ thinner to level the surface but have not got round tuit yet. Long time since last museum quality finish. More work, same $$.
Re: clear finish
John Jordan
I didn't know about the Deft, Russ, thanks. I know I can search, but where do you get it? I'm always interested in something like this. The Krylon products still work pretty well, but not the same as they once were. I think they have all been made to meet CA requirements.
John
Re: clear finish
Deft Acrylic is available at Woodcraft
Greg Haugen
The Deft Acrylic is available at Woodcraft. There's a link below to the "satin" sheen.
www.woodcraft.com/Catalog/ProductPage.aspx?prodid=18908&ss=55c85814-8ce8-4795-ae7b-0abe97da14ac
We also have it locally at a "farm supply/hardware" store.
Re: clear finish
Re: Deft Acrylic is available at Woodcraft
Cyril Griesbach
Greg, would that be Fleet Farm? The one over here doesn't carry Deft products anymore.
Re: clear finish
Greg Haugen
It would be the "Blain's" Farm and Fleet, not the "Mill's" Fleet Farm. I'm not sure which one you have over there. Our Blain's has Minwax/Cabot, Watco, and Deft.
Re: clear finish
Re: clear finish
Russ Fairfield
The Deft Acrylic leaves brush and wiping marks than Deft Lacquer.. That means wet sanding with 400 and 600 to level and smooth the surface, and then sanding and polishing to whatever gloss you want it to have. Buffing works great after the surface has been leveled with the sanding. This is best done after an overnight wait.
It is too new to tell what happens to it with age.
This is a much harder finish than the Minwax or similar Poly-Acrylics.
Re: clear finish
eliot d
Is the new Deft acrylic water based? Or is this a dumb question;e.g. perhaps being acrylic implies solvent based?
Re: clear finish
Yes, the Deft Acrylic is a waterborne finish.
Russ Fairfield
