acorn boxes
acorn boxes
acorn boxes
I had my threader out the other day and decided to do some acorn boxes like Willard Baxter used to do. These are fun but texturing the lid is real pain. I like the round dremel cutter the best but it takes quite a while to do that texture. I use the Dremel engraver with a rounded bit to do the second one. That goes faster but doesn't look as good. It takes longer to texture the lid than it does to make the box.
I'll try the Sorby texturing tool next but I think the pattern will be to rhythmic to look like it should. I'll find out. Anyone have a better idea for a quick texture.
My best friend made these for years without the screw thread and he just used maple for the lid and burned it with a piece of cardboard. It looks pretty good considering it takes about 10 seconds to burn the texture vs about 15 to 20 minutes for the Dremel and ball.
Re: acorn boxes
I need more caffiene forgot the photo
Re: acorn boxes
Dennis in Southern Oregon
Re: acorn boxes
John, I have made a few using a woodburner with a small ball tip to stipple the acorn cap. I expect that this is a bit faster than the dremmel tool. Dennis
Re: acorn boxes
Re: acorn boxes
bob davis
very nice. willard would be proud, i have a similar ornament.
Re: acorn boxes
Scaler/Descaler
Ed Moore in SW VA
I use an air operated descaler like a welder might use to clean a weld to do texturing of this type. It came from Northern Tool, I think.
Ed
Re: acorn boxes
Re: Scaler/Descaler
Molly Winton
I use a needle scaler too. Less than a minute to get the texture. I like the first one with the dimples John. It looks more authentic than the engraver. Sweet little boxes, by the way.
Re: acorn boxes
Very nice!
I want to do some! My Baxter threader came with his instruction sheet for these.
Have you tried a less glossy finish on the top? Might let the texture show better, at least in a photo.
The needle scaler I got from Northern needs the end of each wire/rod smoothed so the sharp edges don't tear the wood.
Re: acorn boxes
Re: acorn boxes
Don at Central Illinois
How would he burn it with a piece of cardboard? Doesn't seem like that would put a texture on it.
Re: acorn boxes
Re: Scaler/Descaler
charlie belden
Picked up a "descaler" at Harbor Freight for under $25. The "needles" were a bit LONG so I shortened them then rounded the ends a bit. Works OK - but probably not on small stuff.
Re: acorn boxes
Re: Scaler/Descaler
Charlie that's what I was worried about. THese are pretty small and although not overly thin I don't know if a needle scaler will work. They aren't very expensive however so I may pick one up and see.
Re: acorn boxes
Re: acorn boxes
Don It's not a texture just a burn but looks pretty good. I'll try to do one in the next few days and show you how it looks. Randy just folds the cardboard so the endgrain ( if you can use that term) is rubbing the wood. He says the cheap chinese boxes work better than the stiffer American cardboard. I should tell you that Randy only has one speed on his lathe, Fast. We kid him about it whenever he does a demo. 25 years of production turning do that for you.
Re: acorn boxes
Mike Stafford
Re: acorn boxes
Mike Stafford
I love little boxes like this John. These are very well done. Post some more...
