Question on platter blank/Feather
I had a arborist bring me some pieces of oak from a neighbor's yard. Told him I would like a couple of crotch or branch union pieces with the "Y" in them. He obliged, but when I cut one open I found there was little or no feather and a long thin (1/8 to 1/4") bark inclusion running almost full length. The question is about the Bark. I think it has No Strength and if I turn the blank and leave it in the player (all the way through) the blank will fall apart or certainly fail along the line. Am I right on this? Is the blank worthless?
Re: Question on platter blank/Feather
Tery Scott
More than likely you will end up with 2 pieces as the seem or were the 2 branches have grown separately then come together may appear to be stuck together will have an invisible weak point .I wouldn't risk it myself
I have turned the inside first then added biscuits or butterfly's with my biscuit jointer in a contrasting wood .But being wet glueing can be a problem
George Balock
George Balock
Barry,
Tery is correct. It probably was where two branches grew so close they grew together. It's firewood.
George
Dennis Ford
This is common with crotch sections where the branches come off at an acute angle. If you get a large piece like this, try cutting it through the bark inclusion instead of through the piths. There will usually be a lot of figure on each side of the bark inclusion. The figure will not be deep so this only works for platter shapes
