Wolverine vari-grind question...
Scott Burr in Ben Lomond CA
If I were to get one should I get the original with the updated clamp or the vari-grind 2?
Scott, preparing to go shopping :D
Re: Wolverine vari-grind question...
Re: Wolverine vari-grind question... *LINK*
Fred Holder
I've been using the Wolverine Vari-grind system since 1989 and recently got the Vari-grind upgrade kit. I find it an excellent system. I do recommend that you also get the Raptor Set up Tools from Craft Supplies in all five angles.
More Woodturning magazine
Re:I recommend the original, as the .....
JamieDonaldson
....."Mark II" has some limitations in grinding tools other than bowl gouges. I grind my detailing and spindle gouges with the old style jig, and my jig is reallllllly old!
Scott I just spent a week at the Folkschool and played with both back and forth. I like the old one better. I have more options. I grind 2 or more bevels on my tools. It's very easy with the old jig. I simply grind the main bevel with the tool in the back of the V arm and them I move the long arm forward to the front of the V and grind the secondary bevel. Then I lift it out of the V arm and grind off the sharp edge at the bottom. I can't do that with the new jig.
The new jig is narrower which does allow you to sharpen tools where the flute has gotten too short.
I do like the new bearing lock down and will probably order one for my old jig.
I guess the new jig is safer in terms of not dropping the tool off the stone but then I've never really had this problem and I like being able to move the tool across the stone to even out the wear of the stone.
See Kirk DeHeer's article
Jerry Hall
in AAW magazine, by Kirk DeHeer "Sharpening Demystified," Volume 21 Issue 4, Pages 32--34 for the best overview on using the Wolverine. This article (and all others) is available free to AAW members via the members only page on the AAW site.
Also save approx $50 and make your own Raptor equivalents easily as shown in the above article.
The videos in the following link from Oneway show simple and effective ways to use the Wolverine for all your tools:
http://www.oneway.ca/multi-media/wolverine_videos.htm
And the following excellent sharpening video shows a simple angle setup system using a protractor and sharpie. Works fine for me. You soon know when your wheel matches the tool bevel just by hand spinning the wheel, listening for a smooth sound, and maybe looking to see if the sharpie marks are equally removed on the bevel. The Raptor system results in several more rarely needed tools, that cost, and get lost IMHO. Make your own as above or do without. The video is at:
http://www.woodworkingonline.com/2008/09/23/podcast-37-turning-tools-sharpen-your-skills-with-sharp-tools/
I too still like the original Varigrind with the bearing lock down improvement.
Steve Criscenzo
I have both. I intended to seel My VG1 when I got the VG2 But I find that I use them both. I use mainly two angles for my tools so I have the VG2 set up for my Thompson bowl gouges that I do 80% of my turning with. I have the VG1 set up for my detail gouges.
For me, they are both good tools.If I were buying one today, I think I would stick with the VG1 (only because old habits die hard). But for a newer turner, the VG2 is safer, and gives a quick consistent grind. You loose a bit of fleibility with some grinds but it is not a big issue for me. You will have to dress the wheel the wheel a bit more often with the VG2 but you never have to worry about the tool running off the center of the wheel.
Cyril Griesbach
I, too, looked at both at the Ohio Symposium and I'm in agreement with the majority here. The VG2 helps prevent going off the wheel but that's little help for a small issue considering it's other restrictions. I did upgrade mine with the new bearing hold down and I like that a lot so IMHO I'd say go with the upgraded original.
John
Is it necessary to use an 8" grinding wheel vs. a 6" grinding wheel with the Wolverine system? My Craftmans 6" grinder is old and the bearings are pretty shot, so looking to get a new one. 8" or 6" variable speed. Cost is a factor. What about settings for Ellsworth grind jig set up?
Tery Scott
I have a wolvine and a wood cut ,Id recommended the woodcut true grind as the price is well short of the wolvine and they do the same thing if not better
Russ Fairfield
No help from me. I still use the original Wolverine jig with the fixed arm, after bending it to a setting that works for both spindle and bowl gouges. I did add the new bearing clamp and that helps clam them when they get short. I grind all odd shapes by hand.
Charles Watson
Get the original vari-grind or a Sharpfast.
Jennifer Indy.USA
I bought the bearing clamp too Russ. Much better than the original.
Carole Valentine
I keep trying to remember to get the new clamp. Some of my gouges are getting too short for the old spring type.
Hi John,
Yes, The wolverine will work with a 6" grinder. Look at the video Jerry posted.
Cheers!
