Twice turned platter questions?
The Local turning club had Jimmy Clewes demo for two days last weekend. (Great Demo, if you get a chance, go.) Jimmy turned a platter out of oak. I have done tons of bowls, not so many platters. A neighbor had some oaks taken down (shame on him) and the arborist brought me several pieces of wood. I prepped four bowl/platter blanks and took them to the regular turning club meeting to put into a silent auction or what ever thinking someone might want some nice quartersawn blanks to turn a platter like the one Jimmy turned. Club President said we were going to stop doing the silent wood auction for fear of offending the owner of the WoodCraft Store where we hold the meeting. I had already humped two of the blanks into the store, so I solved that problem by giving them to the store owner.
So, the question is how to best preserve the two blanks I have remaining. They are about 3" thick and 13" in diameter. Wet as they can be, they were a tree three days ago. I know I could wax them, but that just appears to delay the inevitable. So, If I rough turn them Into a somewhat serpentine platter, how thick should I turn them? I know the rule is ten percent. but in this case I am worried about the rim going wavy.
Re: Twice turned platter questions?
PS Or would you just
turn them to finish and hope for the best?
John Veerkamp, Western Mo
I rough turn platters/plates about 1" thick. it usually works fine. The only time I've had problems is when the plate is end grain and the pith wants to split the outer rim.
I usually do the wrap in paper and change daily routine to even out the drying.
John
Carole Valentine
My experience with Oak (bowls only - no platters) is that it does warp a fair amount so be sure to leave yourself enough to turn it round in the end. Once it is roughed turned to a fairly even thickness, cracking should be minimal. It will appear to open up along the rays during the first half of drying, but then closes back up as drying is completed. If you finish turn it thin, it can be porous enough that a vacuum chuck will struggle.
Barry If you turn platters thin to final thickness they usually warp quite a bit. Some are OK and some warp in such a way they look funny.
I don't do a lot of this so take it with a grain of salt. I rough turn them leaving it larger than I want. The out of round is usually worse than cupping but not always. Seal the end grain areas with Anchorseal or even better wax. That usually works. This works pretty well but I have had some loses.
What I have had better luck with is leaving the wood a little long since most of my failures have been end grain. I seal the end grain and store them in a dry place.
Dennis Ford
I like bowls with warp, but platters just don't look right to me if they are warped. I use the 10% rule, sometimes a little more. I usually wrap them in brown paper and leave them on the shelf for a few months.
Jorge Casta�eda
Hi Barry,
Yes turn them twice, leave them about 1" thick, seal end grain only, so moisture can dissipate, when dry, turn again. To determine "dryness", I weight them, every 2 or 3 weeks, and write date and weight, when I see the same weight as last time, that means they reached equilibrium and they go to the lathe for final turning.
explore the options
jeff Willaford
I've only turned a couple of oak platters/plates to finish from green and they definitely warped. The first people to see them had no qualms at all about laying claim to them. Limited experience but that's what I have to go with. If you have enough wood... explore the options.
