In the Badger Pond days, I got some chestnuts from Sophie (David Sophuson) did I spell that right? The chestnuts came from a live castanea dentata (american chesnut) in his property somewhere in Washington State. That means a tree that survived the blight.
So I planted the chestnuts and some of the sprouted and a dozen or so little chestnut trees gave me a lot of joy, my last name Casta�eda, means chestnut grove. They grew a few years and one harsh winter killed them all but one.
That one stay in a dwarf size several years more and then, it started to grow and grow, now it is at least 12 feet tall and has many trunks, so I think it would be better for it to start several trees from cuttings, actually what I have in mind is to make them take root before separating them from the mother.
They are all over this question and will tell you exactly what to do with your trees. I have a couple American Chestnuts on our property here, but they seem to blight out at an early age. Still, a sharp-eyed ACF scout spotted the trees from the road and came to the house all excited. These folks do great work.
Re: OT How to propagate an american chestnut? *LINK*
Rob Wallace
Hello Jorge!
I did some snooping around in a few plant propagation textbooks I have, and on the 'net...... and made the following observations:
The technique you allude to - propagating the stems vegetatively by rooting in mid-stem without complete removal from the main plant - is termed 'layering'. The technique known as air-layering usually works best with tropical hardwood species, and has only marginal to low success in domestic (temperate) hardwoods. You can search on the internet for various techniques to try rooting young stems by air-layering, but for chestnut (and other hardwoods, it is not likely to work very well, if at all). Using rooting hormones such as indole-3-butyric acid ( or "trade name" rooting hormones with this compound in it; e.g Rootonel) will help improve chances of rooting, however chestnuts, walnuts, pecans, hickories, etc. do not have stem anatomy that is conducive to formation of [adventitious] roots along the stem, so if air-layering works in chestnut, you should consider it to be a very lucky event.
Taking greenwood cuttings in late spring after the new stems have hardened slightly (but have not become too woody) is probably the best method. Using the indole-3-butyric acid rooting hormone and a well drained, yet moisture-retaining rooting medium might provide the best chance of getting vegetative propagules from the one chestnut tree you have. There are many web sites on-line which show the proper techniques for making hardwood cuttings of domestic trees. It seems that a closed, high humidity environment works best for rooting chestnut. (See abstracts at: http://www.actahort.org/members/showpdf?booknrarnr=227_38 and http://www.springerlink.com/content/gv186723828m14j4/)
It appears that most 'rare' chestnuts are propagated by bud grafting onto stocks of other species of hardy chestnut seedlings. If you want to go down this path, there is quite a bit of specialized technique that must be learned.
Another possibility that could be tried is 'ground layering' where you would take a young trunk sprout stem and gently bend it toward the ground so that it can be slightly wounded where it contacts the soil, and might root at that point while still connected to the main plant. (See: http://en.wikipedia.org/wiki/Layering ). Rooting hormone at the wound/base of bend would also be helpful.
I hope that if you do try to attempt some propagation of this tree, that you are at least successful to the point that you get a few new rooted starts to make the effort worth it!
