filling a crack
filling a crack
filling a crack
Guy Bratt
I'm turning a hollowform. The blank had an open crack that I couldn't turn away. Crack is almost 1/16 at it's widest and about 2" long total length. My idea is to mix some colored chalk with some epoxy and squeeze it into the crack. I'm looking for any ideas or comments before I proceed.
Re: filling a crack
Re: filling a crack
Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
Guy, i have used dark sawdust mixed with epoxy or super glue. If the wood is dark, it blends in and if the wood is light, the crack looks like a natural defect.
Roy Girolami
Re: filling a crack
Re: filling a crack
Norm Smith
Guy, I prefer using copper powder with epoxy for cracks and very small voids. It doesnt stand out too much and the copper enhanses the piece. I dont like using wood dust as I can never get it to look like anything other than wood dust. It is all preference. You can buy copper dust at Craft supply.
Norm
Re: filling a crack
Re: filling a crack
Emmett Manley, Lakeland, TN
Brass filings from a key machine at Lowe's, etc., also works well when mixed with epoxy or CA glue. If you use CA glue, you can just pack the crack with the filings (or wood dust) and drizzle in thin CA glue.
Re: filling a crack
Re: filling a crack
Guy Bratt
Good ideas Now how do I effectivly get the epoxy into such a narrow crack?
Re: filling a crack
Re: filling a crack
John Veerkamp, Western Mo
Guy, I use fine coffee grounds. Pack the crack and then drizzle thin ca. make another application if needed to bring it up to level and sand. It is a rich dark brown color that looks like natural defect coloring. make coffee first and use the spent grounds.
John
Re: filling a crack
Re: filling a crack
Guy I've use chalk and all kinds of things to color epoxy. The biggest problem with chalk in your case is that it thickens the epoxy. You can also use oil base paints to color the epoxy and these don't thicken as much or at all. I also use inks and shoe dyes. They work really well although some will simply not mix.
To get the epoxy into the crack either use a thin epoxy such as system 3 mirror coat which gets extremely viscous as it cures or heat whatever epoxy you have. I often use 5 minute epoxy. I'll put it in hot water for about 5 minutes before mixing it and it gets very viscous when you do that. In fact it will become so thin that you have to mix it in a cup of some kind.
Re: filling a crack
Re: filling a crack
Bruce
Thin CA and copy machine/laser toner works well. The CA disolves the toner. I have used toner from a color laser printer with good results.
Bruce
Re: filling a crack
Re: filling a crack
RPE
Sometimes I stablize the crack with CA and then stitch over the crack wth bare copper wire. I dowloaded some lacing patterns and use them to get different looks. I cut a strip of graph paper that will provide even spacing over the crack and then use the lines on the graph paper to locate evenly spaced hole locations. I mark the holes with an awl and drill the holes. Lace it up. It looks like you planned it that way.
Re: filling a crack
Zing at Hobby Lobby
Jimmy Edwards
They have 27 colors. I mix it with clear epoxy.
Re: filling a crack
Dick Hines
Re: filling a crack
Dick Hines
Look in the Wood turners catalog. The sell stone chips and stone dust. The look nice when used to fill cracks. If the crack goes all the way through use a piece of masking tape to keep the stone from falling through.
After filling the crack use thin CA to glue the stone in. give it a good sanding. If you use stone chips you will end up with small pits between the stone chips. Drip so thick CA on the stone and let dry then sand again. The thick CA will fill the voids and make everything smooth.
Re: filling a crack
Re: Zing - little more info please
Steve Harder
Jimmy - do you use just a little or really put in a lot of Zing in your epoxy mix?
Re: filling a crack
Re: filling a crack
Guy Bratt
swmbo suggested food coloring in the epoxy. ??? Lots of great ideas to put into my memory blank for later use. I may go with the coffee grounds this time around. Thanks to all.
Re: filling a crack
MrRules
Re: filling a crack
MrRules
Another vote for used coffee grounds and CA glue. Depending on the size of the crack you can use thin, medium, or thick CA after filling the crack with the coffee grounds. The surface sands down nicely and the crack now becomes an artful part of the piece. As was also mentioned it may take a second effort to get the crack totally up to the same level as the rest of the surface.
Stu
