John, those hollowers are 5/16" in diameter so I would guess the vessel is around 2�" tall or less. I've got the twoi curved ones for Christmas ornaments and for working around the opening of hollowforms. I really like them.
Steve the double grind means a very small bevel area .I havnt fiquerd out why yet but the cut I am getting with my bowl gouges and even scrapers like these is noticebly better
Scrapers know have a bevel area so burnish as they cut
Eli sharpened all of my tools even my detail gouges .Facing off end grain this has stopped dig ins as well
Mike Mahoney does a similar grind
I am sure if you email Eli hed only be to happy to explain or get his new Dvd on sharpening from Karl tikcle
I think there is a spindle gouge ground with a double grind/secondary grind in that group.
If you have Ellsworth's new book, he shows his spindle gouge with the heal ground away completely so it is one smooth curve from the tip back to the shaft. I believe that would be the extreme (not much harder to do) of what is done by a double grind/second bevel. This should minimize bruising caused by the heal dragging behind the cutting edge when riding the bevel.
That 2nd short bevel below the cutting edge of a hollowing tool has been around for 20 years that I know of. It is what Dennis Stewart ground on his tools, and what everyone removed when they sharpened the tool on the grinder.
This is a short bevel that Dennis said should be no more than 1/16" wide and at 90-degrees to the top of the tool. The rest of the bevel is at a greater angle to clear the wood and allow hollowing to a smaller inside diameter.
That short bevel below the cutting edge does the same thing as the bevel on any other turning tool - it is a point of control that provides support for the wood while it is being cut and it prevents the tool from digging into the wood. The result is a more controllable cut with the hollowing tool, and a better finish.
