does anyone use...
does anyone use...
does anyone use...
GaryG in MD
the Wolverine skew grinding jig?
Does it work?
Is it worth having?
Sounds like it helps get rid of the hollow grind. ...Gary
Re: does anyone use...
Dennis in Southern Oregon
Gary, IMHO it has little value. I went to the trouble of making one when they first came out and didn't like it. The best way in my opinion is to use the adjustable table that comes with the Oneway sharpening system. Set the angle of the table to match the grind of the skew. Then slide the skew along the table keeping the skew edge aligned crosswise to the wheel. If the skew has a curved edge, rotate the skew on the table slightly as you slide it to keep the part of edge being ground crosswise to the wheel. Regarding the hollow grind, there is lots of controversy as to whether it is good or bad. If you don't want it, you can remove it easily after sharpening by stroking the skew upward on the table slightly so that the skew edge lifts off of the wheel. Dennis
David Churnega
It simplified the process of sharpening bowl gouges for me.
Jeff Willaford
A friend loaned me their Wolverine skew jig long enough for me to realize my overall length of tool plus handle was too long for the jig... and my 1" skew is a standard Packard 16" overall. I continue to sharpen as Dennis said.
Bill Blasic
Bill Blasic
Gary,
I bought it with the Wolverine set. To me it was worthless and when one of my club members mentioned that he was interested in it I gave it to him. Kurt Hertzog showed me how he sharpened a skew using the Veritas Grinding Jig. If you ever get a chance to see his sharpening demo he probably shows it then.
Bill
Carole Valentine
Have one and it's one of those items that just sits in a drawer collecting dust. It works if you have short skews, or no guards on your grinder, but I would just as soon grind them by hand. Once it's right, you don't have to grind a skew too often anyway - just hone.
I'll add my vote...
Greg Haugen
...that it's a good idea but not practical. By using it your angle can only be that one angle. Just like bowl gouges, people do you prefer different angles. I've seen everything from 45 degree skew angle to almost 90 degree skew. The skew I use the most is a Lacer Skew 5/8" by Hamlet. There's no way to grind a radius on a skew with it. You'll be more versatile to "platform" sharpen your skews, as Dennis said. It will also get you used to grinding on a platform which will help with scrapers as well as gouges if you choose to "platform" sharpen them as well.
Re: I'll add my vote...
Emmett Manley, Lakeland, TN
It works well for me if the skew handles are not too long. If the handle is long or the skew flat (not rounded) I use the platform.
Gary I bought it, don't use it. I built a sliding table that rides on the Oneway tool rest. The table has a V shaped raised area in the middle that matches the left and right angles of the skew. Put the skew on and adjust the angle for your bevel. Then just hold the skew and slide the jig back and forth across the tool rest.
It works with any size skew but only gives you a straight grind. If I thought about it long enough I could probably make jig to grind the Lacer skew grind. All it would take is a to make an upper platform with a few pins and a lower platform with some guide slots. Maybe I should get with Oneway and design one.
If you want a photo of my skew jig I'll post one tonight.
Well, that was a resounding "NO"
GaryG in MD
Thanks everyone -- you just saved me some money and taught me how to do it the right way. That's why I love WC.
Yes, John, please post your photo -- it'll help me understand your writeup.
Much appreciated, Gary
Skew Jig
Jorge Casta�eda
Gary,
with a few scraps and a lavish time investment of about 3 minutes, you can slap something like this:
I made this to use with the Veritas table, the horizontal piece at the bottom protrudes past the main rest and slides on the slot of the Veritas table, you can make your own table (hint, hint)
I only use it when I hafta, most of the time I just use the diamond files on top and when I want a mirror edge, I use the hard Arkansas oil stone.
As you can see, I prefer to sharpen without the handles...
My $0.03 adjusting for inflation.
Jorge
Re: Well, that was a resounding "NO"
Carol Reed
It certainly was - one day after I ordered one! :( >(
just return it...
GaryG in MD
You should at least be able to get "store credit" if not a refund. Depends on the postage cost, of course. I almost bought one, but figured I'd ask first -- sure glad I did. Good luck with yours, Gary
Re: Skew Jig
GaryG in MD
Thanks Jorge, That's a valuable primer. Thanks, Gary
Re: My Skew Jig
Like Jorge I use diamond hones most of the time to sharpen the skew by hand. I sharpen on the grinder to get a concave grind and then use the diamond hones that sit on the high spots of the concave to sharpen. When the flat areas that these hones grind get too big to let me sharpen quickly then I go back to the grinder.
The jig in this photo is for my oval skew. I ground out slots in the jig so the oval sits flat. I also have jigs for my flat skews.
Re: My Skew Jig
eliot d
Now that everyone has given you a pretty resounding,'NO', I'll go ahead and say that I have one and use it a fair amount of the time; there's nothing wrong with using it for some skews.
Very nice John...
GaryG in MD
Thanks for the excellent photo. I guess I'll be making something similar. ...GG
Re: My Skew Jig
GaryG in MD
Thanks Eliot -- we missed you Saturday. You would have enjoyed it. ...GG
Re: Does it slide
Steve Criscenzo
John
Do you use the Wolverine table and just slide you jig along the table? Is it captive on the table, i.e. runners top and bottom, or do you use just one runner.
Nice looking jig. I plan on making one this weekend. Thanks for sharing.
Steve
Re: Does it slide
I made the first one with a lip on the top end that just slid against the Oneway tool rest. Then one day I decided to try out my new milling machine and cut a slot in the tool rest. Now I fasten 1/8" x 1/2" aluminum bar to the bottom to ride in the milled slot so it's captured and slides left and right.
